4 Channel DCSSR Assembly Instructions
Revision as of 23:15, 10 November 2007 by Wjohn (talk | contribs) (→‎Background)
Background
The board is a simple design, and follows the standard connection for an AC SSR COOP board. THe RJ45 Socket provided the connection to the Controller. The LED on the board indicates 5VDC is being supplied from the Controller to the OPTO.
The OPTO, which is different to the MCO3023Ms used on the AC SSR, is a K84PH, 16 pin DIP IC. I purchased mine from Mouser. 782-K847PH was the Mouser Part # and they cost $1.02 each. and the datasheet is here Datasheet
Parts List
 4 MOSFETs  512-RFP14N05L
 1 OPTO 782-K847PH
 5 680 ohm resistors
 4 470 ohm resistors
 4 10k resistors
 1 LED
 1 RJ socket
 1 7805 or 78L05
 5 538-39890-0302 Screw terminals
Completed DC SSR
