SPT Wire and Vampire Plugs
SPT Wire ( SPT-1 SPT-2 )
- SPT stands for Stranded, Parallel, Thermoplastic wire. SPT is frequently known as Zip cord or Lamp Cord. SPT IS NOT SPEAKER WIRE OR LOW VOLTAGE LANDSCAPE WIRE!! SPT wire is rated for 300V or 600v, low voltage wire and speaker wire are not!!!
- SPT is commonly used by Christmas lighting enthusiasts to create low cost custom length power cords utilizing Vampire Plugs and Sockets. SPT is commonly sold on spools of 250, 500 and 1000ft. SPT Wire comes in different wire gauges, 18awg is the most common. A common 18awg SPT-2 wire from one vendor has a rating of 10A.
- SPT comes with different insulation thicknesses, the higher the number the thicker the insulation. SPT-2 has thicker insulation then SPT-1. The SPT rating is related to the thickness of the insulation that surrounds the copper wires. SPT-1 wire has an insulation thickness of .030″ and SPT-2 has insulation that is .045″ thick.
- SPT wire is polarized and generally comes with two different wire textures on the wire pair to help identify the polarity when you hook it up. One wire is smooth, it is generally used for the Hot or Line wire. The other wire is usually ribbed, it is generally used for the neutral wire.
- IMPORTANT: IT IS CRITICAL THAT YOU CONNECT THE CORRECT CORRECT TERMINAL TO THE CORRECT WIRE ON BOTH ENDS! ALL PLUGS AND SOCKETS ON THE WIRE SHOULD BE WIRED WITH THE NEUTRAL TERMINAL CONNECTED TO THE RIBBED WIRE AND THE HOT (LINE) WIRE CONNECTED TO THE SMOOTH WIRE.
Male Plug
- The narrower blade is hot (or Line) blade. It is generally attached to the smooth wire on the SPT wire.
Female Plug
- The narrower socket hole is hot (or Line) hole. It is generally attached to the smooth wire on the SPT wire.
Female Inline Plug
Female inline sockets are designed to go in the middle of a SPT wire of the correct matching size. Female sockets are polarized and it is important that you install the wire correctly to match the polarity of the wire and plug. The two vampire teeth are designed to each pierce one wire when they are installed. You should look at the socket to identify which tooth is which.
C7 Socket and C9 Socket
- One vampire tooth will connect to the terminal on the side wall of the socket, this is teh neutral terminal. Generally it is attached to the ribbed wire on the SPT wire.
- One vampire tooth will connect to the bottom contact in the socket, this is hot (or Line) terminal. It is generally attached to the smooth wire on the SPT wire.
Installing Vampire Plugs / Sockets
Female Vampire
- Inspect socket for cracks, damage, bent teeth or "Evil Vampires" (both teeth on the same side). Confirm that the vampire is made for the wire type (SPT-1 or SPT-2) that you are using.
- Cut the SPT to the desired length. INSPECT THE END OF THE WIRE AND REMOVE ANY STRAY STRANDS OF WIRE PAST THE END OF THE INSULATION. Make a small cut to separate the ends of the wire slightly. Identify the neutral wire (usually ridged). IMPORTANT: IT IS CRITICAL THAT YOU CONNECT THE CORRECT CORRECT TERMINAL TO THE CORRECT WIRE ON BOTH ENDS! ALL PLUGS AND SOCKETS ON THE WIRE SHOULD BE WIRED WITH THE NEUTRAL TERMINAL CONNECTED TO THE RIBBED WIRE AND THE HOT (LINE) WIRE CONNECTED TO THE SMOOTH WIRE.
- Identify the wider socket side (Neutral) and turn over socket to identify the correct tooth for the Neutral socket hole.
- With the Neutral Vampire tooth aligned to penetrate the Ribbed Neutral wire, insert the SPT into the hole at the end of the socket and gently press down so that the split wire ends are seated into the two pockets in the end of the socket.
- Firmly press the wire into the vampire teeth and seat the wire into the recess. Be careful to avoid pressing at an angle which may bend the vampire teeth over and not make a connection to the wire.
- Slide the back cover firmly onto the wire . Make sure that the sloped end slides on to the plug first. It may be helpful to use a Channel Lock Pliers to help seat the back cover firmly on.
- Inspect the assembled unit for cracks or poor connections.
Female Inline Vampire
- Identify the neutral wire (usually ridged). IMPORTANT: IT IS CRITICAL THAT YOU CONNECT THE CORRECT CORRECT TERMINAL TO THE CORRECT WIRE ON BOTH ENDS! ALL PLUGS AND SOCKETS ON THE WIRE SHOULD BE WIRED WITH THE NEUTRAL TERMINAL CONNECTED TO THE RIBBED WIRE AND THE HOT (LINE) WIRE CONNECTED TO THE SMOOTH WIRE. With the Neutral Vampire tooth aligned to penetrate the Ribbed Neutral wire,firmly press the wire into the vampire teeth and seat the wire into the recess. Be careful to avoid pressing at an angle which may bend the vampire teeth over and not make a connection to the wire.
Male Vampire
- Inspect Plug for cracks, damage, bent teeth or "Evil Vampires" (both teeth on the same side). Confirm that the vampire is made for the wire type (SPT-1 or SPT-2) that you are using.
- Identify the wider blade side (Neutral) and turn over plug to identify the correct tooth for the Neutral blade.
- With the Neutral Vampire tooth aligned to penetrate the Ribbed Neutral wire, insert the SPT into the hole at the end of the plug and gently press down so that the split wire ends are seated into the two pockets in the end of the plug.
C7 or C9 Vampire
- Identify the Neutral socket terminal (on side wall, not bottom of socket hole) and turn over socket to identify the correct tooth for the Neutral socket terminal.
- The back cap is keyed to fit only one way, there is a wider tab and a narrower tab. Firmly press the back cap onto the wire. It may be helpful to use a Channel Lock Pliers to help seat the back cover firmly on. Be careful, the sockets are fragile and too much pressure may crack them.
Vendors
These are selected wire and connectors from the various vendors with a mix of properties. Visit their sites for the latest information and to see their entire product catalog.
Pricing is in US $. Pricing is as of 02-11-13.
Shipping from overseas can be expensive, check with your vendor. WIRE IS HEAVY
SPT Wire
SPT-1
Vendor | Wire | Length | Link | Price | Price per ft | Note |
3G Light Creations | SPT1 | 1000ft | link | $159.95 | $0.16 | Green |
ChristmasLightShow | SPT1 | 250ft | link | $34.95 | $0.14 | Green 18AWG |
ChristmasLightShow | SPT1 | 500ft | link | $69.95 | $0.14 | Green 18AWG |
ChristmasLightShow | SPT1 | 1000ft | link | $132.95 | $0.13 | Green 18AWG |
Creative Displays | SPT1 | 1000ft | link | $200 | $0.20 | Green, White |
Grand Brass | SPT1 | 250ft | link | $40 | $0.16 | Black, 18AWG |
Home Depot | SPT1 | 250ft | link | $42.70 | $0.17 | Black, 18AWG |
Novelty Lights | SPT1 | 1000ft | link | $165 | $0.17 | Green 18AWG |
Skycraft Surplus | SPT1 | 250ft | link | $45 | $0.18 | Black 18AWG |
WLCVentures | SPT1 | 250ft | link | $42.99 | $0.17 | Green 18AWG |
WLCVentures | SPT1 | 1000ft | link | $114.99 | $0.11 | Green 18AWG |
SPT-2
3G Light Creations | SPT2 | 1000ft | link | $169.95 | $0.17 | Green |
ChristmasLightShow | SPT2 | 250ft | link | $41.95 | $0.17 | Black 18AWG |
ChristmasLightShow | SPT2 | 500ft | link | $79.95 | $0.16 | Green 18AWG |
ChristmasLightShow | SPT2 | 1000ft | link | $144.95 | $0.15 | Green 18AWG |
Grand Brass | SPT2 | 250ft | link | $55 | $0.22 | Black 18AWG |
Home Depot | SPT2 | 250ft | link | $45.26 | $0.18 | Black 18AWG |
Novelty Lights | SPT2 | 1000ft | link | $180 | $0.18 | Green 18AWG |
WLCVentures | SPT2 | 250ft | link | $44.99 | $0.18 | Green 18AWG |
WLCVentures | SPT2 | 1000ft | link | $130 | $0.13 | Green 18AWG |
Vampire Plugs
SPT-1
Vendor | Size | Type | Link | Price | Price per Unit | Note |
3G Light Creations | SPT1 | Male | link | $6.95 | $0.70 | Package of 10 Green |
3G Light Creations | SPT1 | Male | link | $6.95 | $0.70 | Package of 10 White |
ChristmasLightShow | SPT1 | Male | link | $6.00 | $0.60 | Package of 10 Green |
Creative Displays | SPT1 | Male | link | $6.00 | $0.60 | Package of 10 (White, Black or Green) |
Home Depot (online) | SPT1 | Male | link | $ | $ | Only available in season Green |
LEDGenLighting | SPT1 | Male | link | $19.00 | $0.38 | Package of 50 Green |
LEDGenLighting | SPT1 | Male | link | $19.00 | $0.38 | Package of 50 White |
Novelty Lights | SPT1 | Male | link | $0.85 | $0.85 | Package of 1 Green (Discount for quantity 50-149 $0.65, 150+ $0.50) |
Novelty Lights | SPT1 | Male | link | $0.85 | $0.85 | Package of 1 White (Discount for quantity 50-149 $0.65, 150+ $0.50) |
WLCVentures | SPT1 | Male | link | $25.00 | $0.50 | Package of 50 Green |
3G Light Creations | SPT1 | Female | link | $6.95 | $0.70 | Package of 10 Green |
3G Light Creations | SPT1 | Female | link | $6.95 | $0.70 | Package of 10 White |
ChristmasLightShow | SPT1 | Female | link | $6.00 | $0.60 | Package of 10 Green |
Creative Displays | SPT1 | Female | link | $6.00 | $0.60 | Package of 10 (White, Black or Green) |
Home Depot (online) | SPT1 | Female | link | $ | $ | Only available in season Green |
LEDGenLighting | SPT1 | Female | link | $20.00 | $0.40 | Package of 50 Green |
LEDGenLighting | SPT1 | Female | link | $20.00 | $0.40 | Package of 50 White |
Novelty Lights | SPT1 | Female | link | $0.85 | $0.85 | Package of 1 Green (Discount for quantity 50-149 $0.65, 150+ $0.50) |
Novelty Lights | SPT1 | Female | link | $0.85 | $0.85 | Package of 1 White (Discount for quantity 50-149 $0.65, 150+ $0.50) |
WLCVentures | SPT1 | Female | link | $25.00 | $0.50 | Package of 50 Green |
Creative Displays | SPT1 | Female Inline | link | $6.00 | $0.60 | Package of 10 (White, Black or Green) |
WLCVentures | SPT1 | Female Inline | link | $25.00 | $0.50 | Package of 50 Green |
