E1.31 (Streaming-ACN) Protocol
Protocol Description
sACN is ethernet based and is sent via UDP. The two accepted transport methods are multicast and unicast, the most common implementation is multicast. When using multicast all the controller needs to do is subscribe to the multicast address for the universe that you want to receive data from.
More Information
Code Example and Draft Copy of Specification
Article: E1.31: An Offer You Can't Resist
Using E1.31 with Vixen
Using E1.31 with LOR S3
Using E1.31 with HLS
Tools
These tools allow you to test E1.31 controllers simply without using sequencing software. They are good tools to use when troubleshooting a E.131 network setup.
sACNView: Sends and Receives Streaming-ACN
da_E131: Sends Streaming-ACN
