General
There are many Different Styles of Pixels that are available with different design features like shape, integrated circuit and voltage available. Choosing the right pixel depends on your specific use plans and one of the most common questions is which voltage pixel should you buy. Choosing between the two most common voltages, 5vdc and 12vdc depends on how you plan to control and how you layout your pixel setup. There are a few general rules:
- Long strings (>50 pixels) are less likely to need power injection if they are driven by 12vdc.
- Long distances from the controller to the first pixel is easier with 12vdc.
- 12vdc power supplies are more expensive per Amp then 5vdc power supplies.
- Some low cost and homemade controllers only work with 5vdc.
- Some 12vdc pixels use less current then traditional 5vdc pixels.
- Voltage drop and power injection are important issues for both voltages.
THIS PAGE IS STILL IN DEVELOPMENT AND SUBJECT TO CHANGE. PLEASE COME BACK SOON!
How RGB LEDs work
Current Limiting Resistors
- What resistor would you use with a 5VDC power supply and a Blue 8mm LED with a VF of 3.0V?
First you need to calculate the voltage that the resistor needs to drop. That is equal to
The table below recommends a current I of 20 ma for a 8mm LED. The formula for resistance gives us:
To calculate the wattage resistor needed you use the formula for Power:
P=VI=(2)(0.02)= 0.04W. You would use the next standard size up resistor, 1/8 W.
Typical 8mm RGB LED Properties | |||
Color | Forward Voltage VF @ 20ma | ||
Minimum | Typical | Maximum | |
Red | 1.8V | 2.0V | 2.2V |
Green | 3.0V | 3.2V | 3.4V |
Blue | 3.0V | 3.1V | 3.4V |
Different Voltage Configurations
5V Power and 1 RGB LED
12V Power and 3 RGB LEDs
12V Power and 1 RGB LED
