Glossary
A
- Amp
- Anode
- AWG
B
- Base
- Baud
- BNC
C
- Capacitor
- Cathode
- Center Tap
- Channel
- COOP
- A co-operative effort by participating DIYC members to pool their resources together to make a purchace of an item(s) in large quantity in an attempt to reduce the cost to the individual participants.
- COOP SSR
- Coaxial Cable
- Collector
- Continuity
- Current
D
- dB
- Decoupling capacitor
- Dielectric
- Diode
- DIP
- Dipole
- DIYC
- Do It Yourself Christmas.com
- DMX (or DMX512)
- Digital Multiplex. A lighting control protocol standard developed to handle communications between commercial (usually entertainment, such as theater or music events) lighting control boards and the individual devices, such as lekos (elliposoidals), fresnels, moving lights, strip lights or DJ effect lights. DMX allows up to 512 devices to be attached, daisy-chain, to one wire, each controlled individually. For more information on DMX click here.
E
- Electrode
- Electrolyte
- Electrolytic Capacitor
- Emitter
- Energized
- ESD
F
- Farad
- The basic unit of capacitance. A capacitor has a capacitance of 1 farad when a voltage potential of 1 volt across it produces a charge of 1 coulomb.
- FCC
- FET
- Firmware
- A software program or set of instructions programmed on a hardware device. It provides the necessary instructions for how the device is supposed to operate.
- Flux
- A solution that removes surface oxides from metals being soldered.
- Full-Wave Rectifier
- A circuit that uses both positive and negative alternations in an alternating current to produce direct current.
- Fuse
- A device that has as its critical component a metal wire or strip that will melt when heated by a prescribed (design) amperage, creating an open in the circuit of which it is a part, thereby protecting the circuit from an over current condition.
G
- GFCI
- Ground Fault Circuit Interrupter. An electrical safety device installed in a power panel, sub-panel or outlet box that instantly shuts off the electricity when a leakage to ground occurs. This leakage can increase the risk of electrical shock. A GFCI should be used in all outdoor high-voltage environments and the device should be tested on a regular basis.
- GRINCH
- A 64 channel controller with basic ON/OFF capabilities. Normally gets its input from the parallel port of the controlling computer. No status LEDs, inexpensive/simple to build. Developed by Robert Jordan (RJ).
- Ground
H
- Half-Wave Rectifier
- A rectifier using only one-half of each cycle to change ac to pulsating dc.
- Heat Shunt
- Heat Sink
- A piece of metal attached to an electronics component (such as microprocessor, microcontroller, Triac, optoisolator) that serves to dissipate or absorb unwanted heat. Many electronics components have two ratings, a lower one when a heat sink is not used and a higher one where a heat sink is in place. Also called a dissipator.
I
- Inductance
- Induction
- Insulated
- Insulation
- Insulation Resistance
- Insulator
- Integrated Circuit (IC)
- Inverter
J
- Jumper
K
L
- LED
M
- Microcontroller
- MOC3023
- MOSFET
- MOV
- Multimeter
N
- NPN
- An NPN transistor is formed by introducing a thin region of P-type material between two regions of N-type material.
O
- Ohm
- Ohm's Law
- Open or Open Circuit
- Oscillator
P
- Parallel Port
- PCB
- PIC
- Polarity
- Potentiometer
- Power
- Programmer
- Protocol
Q
R
- Regulator
- Relay
- Renard
- Resistance
- Resistor
- RJ-45 (or RJ45)
- RoHS
- RS232
- RS485
S
- Schematic
- Short Circuit
- Shunt
- Sink Current
- SMT (or SMD)
- SNR
- Source Current
- SSR
DIYC definition
- SSROZ
- SWR
T
- Tinning
- Transformer
- Transistor
- Triac
- Twisted Pair
U
- ULN2803
- USB
V
- VIA
- A plated-thru hole in a printed wiring board. A via may may exist between one or more adjacent board layers, or through the entire board. A blind via runs vertically between the top [or bottom] side and through one or more adjacent board layers, but not through the entire board.
- Voltage
- Voltage Drop
- Voltage regulator
- An electronic device designed to take a higher voltage and make it conform to a specific lower voltage. Provide a 5-volt regulator with 12 volts as an input and it will put out a steady 5 volts; provide a 12-volt regulator with 13 volts and it will output a steady 12 volts. While some regulators are designed for specific voltages, others can provide a range of voltages depending upon resistance applied; variable voltage regulators can be controlled by potentiometers (i.e.: volume control), so that you can turn a knob and get various voltages depending on where the knob is.
W
- Watt
X
- XLR Connector
- XTAL
- Short for crystal.
Y
Z
- Zener Diode
- Zero Crossing
