Part Substitutions
IC Chips
SN65LBC176AP | Differential Bus Transceivers | SN65LBC176PE4 511-ST485BN 595-SN65176BP |
Renard 16 Renard 24 Renard 64 Renard SS |
579-PIC16F688-I/P | PIC Microcontroller | 579-PIC16F688-E/P | Renard 16 Renard 24 Renard 64 Renard SS |
782-H11AA1 | Optocoupler, Bi-Directional Input | Renard 16 Renard 24 Renard SS | |
859-MOC3023 | Optoisolator, Triac Driver | Renard 16 Renard 24 Renard SS | |
571-1-390261-2 | IC Socket, 8 pin (for U1 & U2) | 575-193308 | Renard 16 Renard 24 Renard 64 Renard SS |
571-1-390261-3 | IC Socket, 14 pin (for U3–U5) | 575-199314 | Renard 16 Renard 24 Renard 64 Renard SS |
571-1-390261-1 | IC Socket, 6 pin (for U8–U31) | Renard 16 Renard 24 Renard 64 Renard SS |
Voltage Regulators
821-TS7805CZ | 5VDC Voltage Regulator | 511-L7805CV | Renard 16 Renard 24 |
511-L4940V5 | Regulator, LDO, 5V, 1.5A | Renard 64 | |
511-LF50CV | Regulator, LDO, 5V, .5A | Renard SS | |
532-574502B00 | Heatsink for Voltage Regulator | Renard 16 | |
532-577102B00 | Heatsink for Voltage Regulator | Renard SS | |
532-7136DG | Heatsink for Voltage Regulator | Renard 24 |
Diodes, LEDs, Triacs
78-1N5239B | Diode, Zener 9.1V .5W | Renard 16 Renard 24 Renard 64 Renard SS | |
78-1N5229B | Diode, Zener 4.3V .5W | 512-1N5229B_T50A | Renard 16 Renard 24 Renard 64 Renard SS |
604-WP63ID | LED, 5mm Red | Any standard 5mm LED will work as a replacement | Renard 24 |
604-WP1503GD | LED, 5mm Green | Any standard 5mm LED will work as a replacement | Renard 24 |
604-WP7104EC | LED, 3mm Red | Any standard 3mm LED will work as a replacement | Renard 16 |
604-WP7104IT | LED, 3mm Red | Any standard 3mm LED will work as a replacement | Renard SS |
604-WP7104GT | LED, 3mm Green | Any standard 3mm LED will work as a replacement | Renard 16 Renard 64 Renard SS |
859-LTL-403G | LED, Rectangular, Green | 859-LTL-403HR - Red 859-LTL-403Y - Yellow |
Renard 64 |
625-1N4001-E3 | Diode | Renard 16 Renard 24 | |
625-1N5817-E3 | Schottky Diode (20V, 1A) | Renard 64 Renard SS | |
821-DB102G | Bridge Rectifier, 1A 100V | Renard 24 | |
511-BTA08-400B | Triac, 8A 400V | 511-BTA04-700T Triac, 4A 700V (alternative Triac for use with LED light strands) |
511-BTA04-700T | Triac, 4A 700V | Renard SS |
Resistors
291-120-RC | Resistor, Carbon Film 120 ohms 1/4W 5% | 271-120-RC 660-MF1/4DCT52R1200F |
291-1K-RC | Resistor, Carbon Film 1K ohms 1/4W 5% | 271-1K-RC 660-MF1/4DC1001F (Renard 24 ZC resistors) |
Renard 24 |
299-1K-RC | Resistor, Carbon Film 1K ohms 1/8W 5% | 271-1K-RC 660-MF1/4DC1001F (Incoming data circuit resistors only) |
299-27K-RC | Resistor, Carbon Film 27K ohms 1/8W 5% | 271-27K-RC 660-MF1/4DLT52R2702F |
291-680-RC | Resistor, Carbon Film 680 ohms 1/4W 5% | 271-680-RC | Renard 24 |
299-680-RC | Resistor, Carbon Film 680 ohms 1/8W 5% | Renard 64 Renard SS | |
291-180-RC | Resistor, Carbon Film 180 ohms 1/4W 5% | 271-180-RC 273-180-RC |
71-CCF60-15K-E3 | Resistor, Metal Film 15K ohms 3/4W 1% | Renard 16 | |
291-750-RC | Resistor, Carbon Film 750 ohms 1/4W 5% | Renard SS | |
299-750-RC | Resistor, Carbon Film 750 ohms 1/8W 5% | Renard 64 | |
299-330-RC | Resistor, Carbon Film 330 ohms 1/8W 5% | Renard 64 | |
266-680 | Resistor Network, 10 pin, 680ohms 2% | Renard 16 | |
264-330 | Resistor Network, 6 pin, 330ohms 2% | Renard SS | |
652-4608X-1LF-680 | Resistor Network, 8 pin, 680ohms, Bussed 2% | Renard 64 |
Capacitors
81-RPEE41H105M4K1E12 | Capacitor, Monolithic Radial Lead 50V 1uF | Renard 16 | |
80-C410C104M5U | Capacitor, Axial Ceramic 50V 0.1uF | Renard 16 | |
581-SA105E104MAR | Capacitor, Axial Ceramic 50V 0.1uF | Renard 24 | |
140-HTRL25V10-RC | Capacitor, Electrolytic 25V 10uF 105°C | Renard 24 | |
140-XRL25V1.0-RC | Capacitor, Electrolytic 25V 1uF 85°C | Renard 24 | |
140-XRL16V6800-RC | Capacitor, Electrolytic 16V 6800uF 85°C | Renard 64 | |
140-XRL16V2200-RC | Capacitor, Electrolytic 16V 2200uF 85°C | Renard SS | |
80-C322C104K5R | Capacitor, Radial Ceramic 50V 0.1uF | Renard 64 Renard SS | |
140-XRL16V47-RC | Capacitor, Electrolytic 16V 47uF 85°C | 140-XRL16V47-RC-TB | Renard 64 Renard SS |
Other
838-3FD-320 | Transformer, Dual Primary/Secondary | 838-3FD-316 | Renard 24 |
838-3FS-312 | Transformer, Single Primary/Dual Secondary | Renard SS | |
520-TCF1843-X | Crystal Clock Oscillator, 18.432 MHz (full size) | Renard 24 | |
520-TCH1843-X | Crystal Clock Oscillator, 18.432 MHz (half size) | ACH-18.432MHZ-EK | Renard 16 Renard 64 Renard SS |
538-22-03-2021 | Header, 2-Pin PCB | 538-22-28-4360 Header, 36 Pin Breakaway (used to make smaller headers) |
538-22-03-2031 | Header, 3-Pin PCB | Renard 24 | |
151-8000 | Shunt | 571-3828115 | Renard 16 Renard 24 Renard 64 Renard SS |
504-GMA-10 | Fuse, Fast Acting 10A 125VAC | Renard SS | |
504-GMA-15 | Fuse, Fast Acting 15A 125VAC | Renard 16 Renard 24 | |
504-1A3399-10 | Holder, Fuse Clip PCB mount 5mm | Renard 16 | |
534-3517 | Holder, Fuse Clip PCB mount 5mm | Renard 24 Renard SS | |
534-3527C | Cover, Fuse Clip | Renard SS | |
571-5556416-1 | Jack, Modular RJ45 PCB Mount Top Entry | 571-5564161 | Renard 24 Renard 64 Renard SS |
571-5520251-4 | Jack, Modular RJ45 PCB Mount Side Entry | Renard 16 Renard 64 | |
636-182-009-213R531 | Connector, D-Sub Female, Rt Angle PCB mount, DE9` | Renard 64 | |
152-3409 | Connector, D-Sub Female, Rt Angle PCB mount, DE9` | Renard SS | |
538-39890-0302 | Terminal Block, 2 Pos 5.0 mm | Renard 16 | |
571-2828372 | Terminal Block, 2 Pos 5.08 mm | Renard SS | |
571-7969492 | Terminal Block, 2 Pos | Renard SS | |
571-7969494 | Terminal Block, 4 Pos (Input Power) | Renard 24 | |
571-2828376 | Terminal, 6 Pos | Renard 24 Opt#1 | |
651-1725041 | Terminal, Dbl Stack 4 Pos | Renard 24 Opt#1 | |
534-1287 | Terminal, Spade | Renard 24 Opt#2 | |
534-4902 | Male Sturdi-mount Terminal | Renard 64 | |
159-2215 | Vinyl Insulated Couplers (Female) | Renard 64 |
