Renard 16 PCB Assembly Instructions
Revision as of 05:29, 29 January 2011 by Ravinglunatic (talk | contribs) (Related Links)
Board Assembly
New assembly instructions are being developed. Until they are finished continue to use the instructions found here.
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
As part of an effort to standardize the parts used on all the Renard systems, the following BOM has had several parts replaced compared to previous versions of the BOM. Any parts that were purchased based on the previous BOMs can and should still be used to populate the board.
PART NUMBER
(Mouser PN# unless noted)
QTY REF NOMENCLATURE
579-PIC16F688-I/P 2 U1, U2 PIC Microcontroller
859-MOC3023 16 U3-U18 Optoisolator, Triac Driver
782-H11AA1 1 U19 Optocoupler, Bi-Directional Input
595-SN65LBC176AP 2 U20, U21 Differential Bus Transceivers
595-SN65LBC176PE4
511-ST485BN
595-SN65176BP
    Sub Diff Bus Transceivers
different power consumptions and ESD ratings
sub at your own risk
821-TS7805CZ 1 5V REG 5VDC Voltage Regulator
532-574502B00 1   Heatsink for 5V REG
78-1N5229B 1 D1 Diode, Zener 4.3V .5W
78-1N5239B 1 D2 Diode, Zener 9.1V .5W
625-1N4001-E3 1 D3 Diode
511-BTA08-400B 16 D4-D19 Triac, 8A 400V
511-BTA04-700T     Triac, 4A 700V
(alternative Triac for use with LED light strands)
604-WP7104EC 1 5VDC LED, 3mm Red
604-WP7104GT 2 CHN2DIAG,
CHN10DIAG
LED, 3mm Green
291-180-RC 16 R1 – R16 Resistor, Carbon Film 180 ohms 1/4W 5%
71-CCF60-15K-E3 2 R17, R18 Resistor, Metal Film 15K ohms 3/4W 1%
299-27K-RC 3 R19, R22, R23 Resistor, Carbon Film 27K ohms 1/8W 5%
299-1K-RC 3 R20, R21, R24 Resistor, Carbon Film 1K ohms 1/8W 5%
291-120-RC 1 R26 Resistor, Carbon Film 120 ohms 1/4W 5%
266-680-RC 2 S1, S2 Resistor Network, 10 pin, 680ohms 2%
520-TCH1843-X 1 OSC Crystal Clock Oscillator, 18.432 MHz
81-RPEE41H105M4K1E12 2 C1, C2 Capacitor, Monolithic Radial Lead 50V 1uF
80-C410C104M5U 2 C3, C4 Capacitor, Axial Ceramic 50V 0.1uF
504-GMA-15 2 F1, F2 Fuse, Fast Acting 15A 125VAC
504-1A3399-10 4   Holder, Fuse Clip PCB mount 5mm
571-5520251-4 2 IN, OUT Jack, Modular RJ45 PCB Mount Side Entry
538-22-03-2021 4 J1, J2, J3, J4 Header, 2 Pin
151-8000 4   Shunt
538-39890-0302 11 H1, H2,
Neut, 1-16
Terminal Block, 2 Pos 5.0 mm
Optional Parts
but highly recommended
538-22-28-4360 1   Header, 36 Pin Breakaway
(used to make the 4 – 2 pin jumper/headers)
571-1-390261-3 2   IC Socket, 14 pin (for U1 & U2)
571-1-390261-1 17   IC Socket, 6 pin (for U3–U19)
571-1-390261-2 2   IC Socket, 8 pin (for U20 & U21)
Below is the same parts list as above but it is formatted for direct importing into the Mouser BOM feature. Just copy and paste the list as is. The last 4 parts listed correspond to the optional items listed above.
579-PIC16F688-I/P	2
859-MOC3023	16
782-H11AA1	1
595-SN65LBC176AP	2
821-TS7805CZ	1
532-574502B00	1
78-1N5229B	1
78-1N5239B	1
625-1N4001-E3	1
511-BTA08-400B	16
511-BTA04-700T	16	Alternate Triac
604-WP7104EC	1
604-WP7104GT	2
291-180-RC	16
71-CCF60-15K-E3	2
299-27K-RC	3
299-1K-RC	3
291-120-RC	1
266-680-RC	2
520-TCH1843-X	1
80-C410C104M5U	2
504-GMA-5	2
504-1A3399-10	4
571-5520251-4	2
538-22-03-2021	4
151-8000	4
538-39890-0302	11
Optional Parts but highly recommended
Design Notes/Assembly Tips
VER 1.9.1 Coop Board
Silkscreen Errors/Notes
  • C1 & C2 silkscreen shows 0.1uF should be 1uF
  • Output terminal numbers not in correct order when compared to Vixen channel numbers. Output terminals 9-16 correspond to Vixen channels 1-8 and output terminals 1-8 correspond to Vixen channels 9-16.
Changes from VER 1.9
  • R1-R16 values changed from 178 to 180 ohm
Board Issues
  • Bottom trace for H1 has a break in it. Instructions on how to fix this are located here.
Renard 16 Controller
Original Renard 16 Assembly Instruction wiki
Part Substitutions
