SSRez
Revision as of 10:33, 7 January 2012 by Wjohn (talk | contribs) (Why Another SSR?)
Version 1.3a
Version 1.3a
Why Another SSR?
There are lots of SSR designs out there. However, John's SSRoz is one of the best. It is compact and functions great and without this initial work, the SSRez may not exist! However, a shortcoming of the design was that it was not designed with a specific enclosure in mind. The initial move towards the SSRez involved changing the layout to fit the TA-200 Telephone Demarc Enclosure from YourBroadbandStore.com.
In order to keep the board to a minimum size and the board cost down, the SSRoz has all the neutral connections off board. So, take all the neutrals and connect them with a large wire nut (five 16AWG neutrals!) Once connected, where does the massive chuck of wire go? :) This led to adding terminals for the neutrals...now this is not inexpensive. The cost was offset in part by removing the vertical fuse holder and replacing it with inexpensive fuse clips.
Lastly, the RJ45 connector could be difficult to remove with the locking pin as the pin ends up in a tight corner. A vertical RJ45 jack made this so much easier. Now, some users like the right angle connection. The great thing is that both types will fit the board. So, if you want the "Dino Option" feel free to use the right angled connector.
SSRez Features
  • Designed to fit in the TA-200 Enclosure
  • Made with 2oz Copper boards for 7A total capacity
  • Trace spacing supports 240VAC use
  • RJ45 Jack layout for Top or Side Load for flexibility
  • On board 5V Logic Power LED
  • Triac layout designed with Heat Sinks in mind
  • Separate Terminals for each wire making the connections easier
  • Wiring "channel" makes the connections easier
  • Clean and Distinct Low Voltage/High Voltage Isolation
  • Fuse Position and layout allows for the Optional Fuse Cover
PLEASE NOTE: THE OVERLAY FOR THE TRIACS IS INCORRECT FOR Version 1.3. THE TAB SHOULD FACE THE BOTTOM OF THE BOARD, NOT THE TOP. Rev 1.3a is correct and is now shipping
Small Schematic
Small Schematic
PCB overlay V 1.3 e
PCB Overlay
PCB Overlay
This is the current version of the SSRez (1.3e) with the neon indicator.
Bill of Materials
Mouser BOM
5      660-CF1/4C681J     1/4Watt Axial Leaded Carbon Film Resistors 680ohms 5% marked R5, R6, R7, R8 and R9
4      660-CF1/4C181J     1/4Watt Axial Leaded Carbon Film Resistors 180ohms 5% marked R1, R2, R3 and R4
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional!) also marked U1, U2, U3 and U4
5      571-28228372       Terminal Blocks 5.08MM PCB MOUNT 2P
3                         Screw,#8x1/2" Pan Head Sheet Metal
1      534-3527C          Fuse Cover (Optional)
1      TBD                Resistor, 1/4W, 100kOhm (Optional for Revision 1.3e Boards)
1      TBD                AC Indicator Lamp (Optional for Revision 1.3e Boards)
240VAC Operation
FireGod
If the SSRez is going to be used with a FireGod system, Resistors R5-R8 may need to be changed. If the channel LEDs are used on the field modules AND the interface board voltage regulator is 5VDC, replace R5, R6, R7, R8, and R9 with 510 Ohm Resistors. You must also use the "Sinking Code" in the FireGod Field Modules when using the SSRez.
10. Now its time for the the TRIACs. These pins are large and they can be difficult to solder at first. If you have problems...tin the leads prior to inserting them into the boards. Solder the pins in place and trim the excess. NOTE for Ver 1.3!!! : THE SILKSCREEN FOR THE TRIACS IS INCORRECT. THE TAB SHOULD FACE THE BOTTOM OF THE BOARD (THE RJ45 Side), NOT THE TOP. Version 1.3a has the corrected Silkscreen
15. Install the fuse.
SSRez in TA-200 Enclosure
Wiring The SSRez
Heat Sink
    Template Coming Soon
Troubleshooting
'This section is under construction...please do not use for the time being....
Symptom(s):
  • Channel remains on constantly
  • Channel does not come on when commanded
  • Triac gate resistor burnt/blown
Possible Problem(s):
  • Bad triac
  • Triac in Backwards
  • Bad opto
  • Opto/MOC in Backwards
  • Bad/missed Solder Joints
Troubleshooting Flow
Troubleshooting Steps
  1. Turn OFF AC power
  2. Are any of the triac gate resistors (R1-R4) burnt/blown/damaged?
    • If so, replace that resistor and check the solder pads on the associated TRIAC. Blown gate resistors are usually caused by a missed solder connection on the TRIAC.
  3. Remove the PIC from the controller for this channel.
  4. If not already installed, attach some test lights to the terminal block of the failing channel.
  5. Connect power to the H and N terminal blocks
  6. Turn ON AC power
  7. Test lights should be OFF
    • If the test lights are ON, go to step <XX>
  8. Using the following table, momentarily use a jumper to turn ON the test lights
    • Test lights should come ON when the jumper is connected to the locations in the table. Now this table has eight tests as they are the 8 channels from a single PIC Microcontroller. However, the SSRez has only 4 channels. The channels in the chart for 5-8 are for a different SSRez.
    Controller
    Channel
    Optoisolator Test Lights
    at SSRez
    Connect Jumper Wires between
    1 U1 Channel 1
    U6 IC socket pin 3 and pin 14
    2 U2 Channel 2
    U6 IC socket pin 13 and pin 14
    3 U3 Channel 3
    U6 IC socket pin 12 and pin 14
    4 U4 Channel 4
    U6 IC socket pin 11 and pin 14
    5 U1 Channel 1
    U6 IC socket pin 10 and pin 14
    6 U2 Channel 2
    U6 IC socket pin 9 and pin 14
    7 U3 Channel 3
    U6 IC socket pin 8 and pin 14
    8 U4 Channel 4
    U6 IC socket pin 7 and pin 14
  9. Does the previously bad channel now work? If it does:
    2. Install PIC back into the controller
    3. Begin testing again where previous failure was noted
  10. Turn OFF AC power
  11. Replace the opto (U1-U4) controlling the bad channel
    • Return to step 8 and repeat tests with the new opto
  12. Continue here if replacing the opto did not fix the problem
  13. Turn OFF AC power
  14. Remove the opto (U1-U4) controlling the bad channel
  15. Turn ON AC power
    SAFETY NOTICE:
    location could/can cause some very undesirable results.
  16. Momentarily use a jumper wire and connect between pins 4 and 6 of the opto socket
  17. If the lights still do not come on, it should only be one of the following things:
    • Bad triac
    • Bad/open triac gate resistor
    • Bad solder joints on the triac, opto socket, triac gate resistor or the terminal block
  18. If the lights did come on, measure the voltage at the opto socket pin 1
    It should be 5 VDC
    • If incorrect, check the current limiting resistor (R5-R8) associated with that opto. You should be able to read approx 5 VDC on both sides of the resistor.
    • If correct, then something must have been overlooked during the troubleshooting process. Turn OFF the AC power and reinstall any removed components, then restart the troubleshooting process.
  19. Turn OFF AC power
  20. Remove the opto (U1-U4) controlling the bad channel
  21. Turn ON AC power
  22. Is the test light still ON?
    • If the light is still ON then it could be either a bad triac or possibly a bridged solder joint on the triac, opto socket, triac gate resistor or the terminal block.
    • If the light is OFF, then replace the opto with a new one and retest
Early Prototype Picture
