Revision as of 00:20, 4 April 2012 by Jklingert (talk | contribs) (TM1809)
Pixel/RGB Wiring Colors
Pixels generally have 3-4 wires connected to each pixel:
  1. +5 or +12VDC Power Feed
  2. Ground Power Feed
  3. Data/ Signal
  4. Clock (not on all pixels)
Because pixels are sending control signals down the wires, there is an input set of wires and an output set of wires coming from each pixel. You can generally find markings such as words or arrows that identify the data direction for each set of wires by looking closely at the printed circuit board inside of the pixel. Other clues may include individual pin markings such as "SDO" Serial Data Output, "SDI" Serial Data Input, "CKO" Clock Output or "CKI" Clock Input.
Unfortunately there is no standard wiring color code for pixels supplied by different manufacturers.
DIYLEDEXPRESS.COM Pixels
WS2801 Pixel Strings (input is chip side)
Ground Clock Data +5V Output Side Photo
Blue Green White Red
TM1809
TM1809 Pixel Strip
+12V Ground Data Photo
Red (+) Blue (-) Green (DI/DO)
Other Vendors
Thanks to http://www.auschristmaslighting.com for this great info.
WS2801
WS2801 Pixel Strings (input is non-chip side usually)
Scheme +5V 0V Clock Data Photo
1 Red Blue White Black
2 Red White Green Blue
3 Red Blue Green Yellow
4 Red Yellow Blue Green
5 Black White Red Blue
Sources:
  1. Fasteddy
  2. Blickensderfer
  3. ThaiWay
  4. Stella Black
  5. JPB
TM1804
TM1804 Pixel Module (Square)
Signal Wire Colour Marking
+12V Red +12V
Data Green DI
0V Blue GND
TM1804 Pixel Module (Rectangular)
+12V Red +
Data Green DI
0V Blue -
TM1804 Pixel Strings (Input is on chip side)
Signal Wire Colour
+12V Red
0V Green
Data Blue
LPD6803
LPD6803 Pixel Strip
+12V Red Di
Data Green Ci
Clock Blue St
0V White Li
LPD6803 Pixel String (RGB order)
Signal Wire Colour
+5V Red
0V Yellow
Data Green
Clock Blue
LPD6803 Pixel String (GRB order)
Signal Wire Colour
+5V Red
Data Green
Clock Blue
0V White
Signal Wire Colour
0V Blue
Clock Red
Data Green
+24V Black
P9813
P9813 Pixel String (BGR order) Input is on chip side
Signal Wire Colour
+5V Red
Data Green
Clock Blue
0V White
DC (No IC)
DC RGB Pixel String
Signal Wire Colour
Blue Blue
Green Green
+5 White
Red Red
DC RGB Module (input Left Hand Side)
Signal Wire Colour
+12 Yellow
Green Green
Red Red
Blue Blue
GECE Wiring
http://sandevices.com/documents/GE_Pixel_Wiring.pdf
