Different Styles of Pixels
Styles of Pixels
- Form Factor
- Strips (Usually 5M length)
- Bare board (no waterproofing)
- Hollow Tube
- Solid Tube
- Solid Silicone
- Solid Epoxy Resin
- Modules
- LEDs per meter (Note, many strips have 3 LEDs wired together as an addressable unit)
- 30 LED/m
- 60 LED/m
- Power Supply Voltage (Note: LEDs generally draw 20ma per color, or 60ma (0.06A) per pixel)
- 5VDC
- 12VDC
- 24VDC
- LED Type
- 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
- 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
- 8mm (typically used in strings)
- Control chip and number of wires (3 wire= V+,GND,Data) (4 wire=V+,GND,Data,Clock)
- GE Color Effects (GECE)
- LPD6803 - 4 wire
- D705 - 4 wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- WS2801 - 4 wire
- WS2803
- WS2811 - 3 wire
- TM1803 - 3 wire
- TM1804 - 3 wire
- TM1809 - 3 wire
- TM1812
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- HX512A (Native DMX)
- TLS3001 - 3 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
