Ohm's Law
Revision as of 05:02, 28 October 2012 by Jklingert (talk | contribs) (Power (P))
Ohm's Law
Ohm's Law is a formula that relates the basic electrical properties. These properties can be measured with a multimeter.
V=IR
Voltage = Current x Resistance
Ohm's Law Diagram
Voltage (V)
Voltage is measured in volts (V). Voltage is a measure of the electric potential difference between two points. There are two basic type of voltage:
  • AC Alternating Current
    • Example:
  • DC Direct Current
    • Example:
      • The voltage of a typical NiMh AA battery is 1.25 volts DC (VDC).
      • Many Integrated Circuits require 5 volts DC (VDC) to power them.
Current (I)
  • Example:
Resistance (R)
  • Example:
Power (P)
Power is measured in watts (W). Electric power is a measure of the rate of doing work. The common formula for Power is:
P=VI
Power=Voltage x Current
  • Example:
LED Calculator
Use these calculators to calculate the resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
Pixel Voltage Drop Calculator
Thread
Calculator
