Ohm's Law
Revision as of 15:09, 28 October 2012 by Jklingert (talk | contribs) (Ohm's Law)
Ohm's Law
V=IR
Voltage = Current x Resistance
Ohm's Law Diagram
Voltage (V)
AC Voltage
  • AC Alternating Current
    • Common values:
DC Voltage
  • DC Direct Current
    • Common values:
      • The voltage of a typical NiMh AA battery is 1.25 volts DC (VDC).
      • Many integrated circuits require 5 volts DC (VDC) to power them.
Voltage Formulas
  • V=IR
  • V=√PR
  • V=P/I
Voltage Examples
  1. What is the voltage drop across a 4 Ω resistor that has a current of 0.3A?
    V=IR, V=(0.3)(4)=1.2V
  2. What is the voltage across a 1 W LED that has a current of 0.35A running thru it?
    V=P/I, V=1/0.35= 2.86V
Current (I)
  • Common values:
    • A typical string of 100 count incandescent lights draws 0.33A.
Current Formulas
  • I=V/R
  • I=P/V
  • I=√P/R
Current Examples
  1. How much current flows thru a 680 Ω resistor that has 5V applied to it?
    I=V/R, I=5/680=0.007A (7 ma)
  2. How much current is used by a 75W floodlight using 120V?
    I=P/V, I=75/120=0.625A
Resistance (R)
  • Common values:
Resistance Formulas
  • R=V/I
  • R=V²/P
  • R=P/I²
Resistance Examples
Power (P)
P=VI
Power=Voltage x Current
  • Common values:
Power Formulas
  • P=VI
  • P=I²R
  • P=V²/R
Power Examples
LED Calculator
By using Ohm's Law you can calculate the current limiting resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
Pixel Voltage Drop Calculator
Thread
