SPT Wire and Vampire Plugs
SPT Wire ( SPT-1 SPT-2 )
SPT stands for Stranded, Parallel, Thermoplastic wire. SPT is frequently known as Zip cord or Lamp Cord. SPT IS NOT SPEAKER WIRE OR LOW VOLTAGE LANDSCAPE WIRE!!
SPT is commonly used by Christmas lighting enthusiasts to create low cost custom length power cords utilizing Vampire Plugs and Sockets.  SPT is commonly sold on spools of 250, 500 and 1000ft.  SPT Wire comes in different wire gauges, 18awg is the most common.  SPT comes with different insulation thicknesses, the higher the number the thicker the insulation.  SPT-2 has thicker insulation then SPT-1.
SPT wire is polarized and generally comes with two different wire textures on the wire pair to help identify the polarity when you hook it up.  One wire is smooth, it is generally  used for the Hot or Line wire.  The other wire is usually ribbed, it is generally used for the neutral wire. IT IS IMPORTANT THAT YOU CONNECT THE CORRECT CORRECT TERMINAL TO THE CORRECT WIRE ON BOTH ENDS!
Vampire plugs get their name from the insulation piercing teeth that they have.  They are designed to be used on SPT wire and allow a fast and easy way to terminate a wire.  Vampire Plugs come in different shapes and functions. They come in three basic colors, Black, Green and White.  The common Male Plug and Female Socket made by Zing Ear are rated for 8A @ 125VAC.  Confirm the ratings and wire size by reading the printing on the item or asking your vendor.
IMPORTANT:  IT IS CRITICAL THAT YOU USE THE CORRECT VAMPIRE PLUG OR SOCKET THAT MATCHES YOUR WIRE TYPE!  PLUGS AND SOCKETS ARE MADE FOR SPECIFIC WIRES TYPES, THEY ARE NOT UNIVERSAL.  SPT-1 SOCKETS AND PLUGS SHOULD NOT BE USED WITH SPT-2 WIRE AND SPT-2 SOCKETS AND PLUGS SHOULD NOT BE USED WITH SPT-1 WIRE.
Male Plug
 - The narrower blade is hot (or Line) blade.  It is generally attached to the smooth wire  on the SPT wire.
Female Plug
 - The narrower socket hole is hot (or Line) hole.  It is generally attached to the smooth wire  on the SPT wire.
Female Inline Plug
Female inline sockets are designed to go in the middle of a SPT wire of the correct matching size. Female sockets are polarized and it is important that you install the wire correctly to match the polarity of the wire and plug. The two vampire teeth are designed to each pierce one wire when they are installed. You should look at the socket to identify which tooth is which.
C7 Socket and C9 Socket
- One vampire tooth will connect to the terminal on the side wall of the socket, this is teh neutral terminal. Generally it is attached to the ribbed wire on the SPT wire.
 - One vampire tooth will connect to the bottom contact in the socket, this is hot (or Line) terminal.  It is generally attached to the smooth wire  on the SPT wire.
