Solid State Relays
Revision as of 17:49, 28 September 2007 by Macrosill (talk | contribs) (Wiki Links)
A Solid State Relay, or SSR, is an electronic device that uses low voltage input to switch high voltage on or off. It is used in Christmas displays to allow the controller to switch the lights on and off. This article will show one who is not familiar with the device a basic overview of how it works.
Circuit Diagram
A generic circuit diagram is available for download. Please look here -- SSR schematic
Components
There are a few basic components that make up a Solid State Relay.
Triac
Optocoupler
Fuse
Resistors
Wiki Links
4 Channel SSR Parts ListSean Bowf Coop Board
4 Channel SSROZ Assembly Instructions
Designs
