Creating Basic Effects
Revision as of 02:29, 2 February 2013 by Jlowe (talk | contribs) (updated image and removed "undo button" info.)
Current as of Version 12C.
  • RGB channels can be controlled without concern with the color levels of each underlying channel.
  • Pixels can be grouped into Pixel Planes where complex effects can be as simple as drag and drop without having to think about things on a channel level.
  • With HLS, sequencing thousands of channels becomes quite manageable.
Figure 5-1
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
  • The top row of buttons are basic effects.
  • The second row of colored buttons are the colors set for RGB channels.
Selection Mode in HLS
  • TIP: Sometimes it may appear as if HLS is unresponsive or hung up. Most likely, you are in Selection Mode and HLS is waiting for a selection box to be completed. If things ever appear hung up or unresponsive, press ESC.
Figure 5-2
Basic Method to Create a Selection Box:
  • Use the left mouse button and click in the left-most cell that the effect will be applied to.
  • A dotted line will appear around the cell.
  • Drag the mouse to the right (and down to apply to multiple channels).
  • Click the left mouse button again when in the right-most cell that the effect will be applied to.
  • All of the cells you have chosen will be surrounded by a dotted line. (See Figure 5-2).
  • Note: If you are not happy with your selection, press ESC and draw the selection rectangle again.
Basic Effects
Figure 5-3
Level:
  • Shortcut key: L
  • Level effects are at the same intensity (default 100%) throughout the effect length.
  • To add a Level effect, place a selection box around an area of cells.
  • Press the L key or click the Level button on the menu bar.
  • See Figure 5-3, Channel Tutorial_0006.
Ramp Up:
  • Shortcut key: U
  • Ramp Up effects start at a low level intensity (default 0%) and move up to a higher level intensity (default 100%) throughout the effect length.
  • To add a Ramp Up effect, place a selection box around an area of cells.
  • Press the U key or click the Ramp Up button on the menu bar.
  • See Figure 5-3, Channel Tutorial_0008.
Ramp Down:
  • Shortcut key: D
  • Ramp Down effects start at a high level intensity (default 100%) and move down to a lower level intensity (default 0%) throughout the effect length.
  • To add a Ramp Down effect, place a selection box around an area of cells.
  • Press the D key or click the Ramp Down button on the menu bar.
  • See Figure 5-3, Channel Tutorial_0010.
Modifying Effects
Moving Effects:
  • Moving an effect is to move it from one place in a sequence to another, such as moving it to start 1/2 second later than currently setup.
  • Left-Click on the first cell of the effect to move.
  • Move the mouse pointer to the new location.
  • When satisfied with the change, left-click again.
  • Stretching an effect is to lengthen the time an effect will take place.
  • Shrinking an effect is to shorten the time an effect will take place.
  • Left-Click on the last cell of the effect to stretch or shrink.
  • Move the mouse OUT from the starting cell to stretch or IN towards the starting cell to shrink.
Deleting Single Effects:
  • Deleting an effect is removing the selected effect from the channel.
  • Right-click on an effect and select Delete this Effect.
  • Warning: No confirmation screen will appear.
Deleting an Area of Effects:
  • Deleting an area of effects will remove all the effects inside a selection box.
  • Use the left mouse button to click on the left most cell and drag right (and down, if applicable) to select the end of the area you wish to delete.
  • Left-click again to finalize the selection box.
  • Right-click and select Delete Selection.
  • Warning: Always be sure you know what is contained in the Selection Box. Once it's gone, it's gone!
Copy/Paste Effects:
  • This is copying and pasting of an effect from one area to another.
  • Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
  • Move the mouse to the end of the effect to copy.
  • Left-click to finalize the selection box.
  • Right-Click and select Copy from Selection Box.
  • Tip: Use the shortcuts CTRL+C to copy and CTRL+V to paste.
  • Move the mouse to the desired location for the copied effect, and left-click to finalize the selection.
  • Note: The selection box will retain the size and shape of the copied cells.
  • Press CTRL+V or right-click and select Paste from Selection Box to paste the copied cells.
Modify Effect Attributes:
Figure 5-4
  • Effects can be modified in length, type of effect, intensity, and deleted all from this window.
  • Right-click an effect and select Modify This Effect. The Modify Effect window will appear (See Figure 5-4).
  • Change the effect type using the radio buttons.
  • If the effect is a ramp, you can adjust the beginning and ending intensities.
  • If the effect is a level, you can adjust the overall intensity.
  • For all effects, you can adjust the number of cells.
  • You can also delete the effect by clicking Delete.
Chapter 4: Display Preview Chapter 5: Sequencing Channels and Adding Effects Adding and Using Beat Tracks
