4 Channel DCSSR Assembly Instructions
Revision as of 23:51, 10 November 2007 by Wjohn (talk | contribs) (Design)
Background
Design
The board is a simple design, and follows the standard connection for an AC SSR COOP board. The RJ45 Socket provided the connection to the Controller. The LED on the board indicates 5VDC is being supplied from the Controller to the OPTO.
The load switching is provided by MOSFETs. Mouser stock these parts, RFD14N05L, as part # 512-RFP14N05L and here is the Datasheet
There is a regulated 5V DC supply for the OPTOs, provided by either a 7805 or a 78L05 on the PCB. the PCB has mount holes for the TO-220 or TO-92 case style.
The DCSSR is design to switch DC loads between 0 and 30 Volts. The MOSFETs are rated to great than 10 Amps each, however as fitted to the PCB, I would limit to individual channel load to 2 to 3 Amps max. A suitable heatsink will be required.
Parts List
 512-RFP14N05L 4
 782-K847PH 1
 660-CF1/4C681J 5
 660-CF1/4C471J 4
 660-CF1/4C103J 4
 604-WP7104IT 1
 571-5202514 1
 863-MC78L05ACPRPG 1
 538-39890-0302 5
 571-3902614 1
571-3902614 is an optional IC socket, the rest of the parts are the Mouser part # and quantity required.
Completed DC SSR
