REN 32 Controller Board
(Redirected from Ren 32)
The REN 32 is the latest 32 channel Microchip 16F688 based PIC microcontroller Christmas light controller that can be used with up to 32 AC or DC solid state relay () . The board design is based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed here. Generic information pertaining to current Renard designs (including maximum channel count) can be found on the Renard wiki page. It is capable of running on either 115vac or 230vac main power to the board.
This controller follows the Renard Standardized Series (SS) controller design: a design effort to standardize the board layouts for Renard based systems and to establish a standardized list of components to use in Renard designs. Some of the goals of the Renard SS design effort were:
  • Completely self-contained controller board. All that is needed to start using the board is a data input and an AC power source. No external DC voltage supply or externally generated ZC is needed.
  • On-board LEDs for full support of Renard diagnostics firmware.
The Board
'The Ren32 measures 3.625" X 6.5"
Board Availability
The PCB is available from DIYLEDExpress.com as well as a PCB/BOM Kit.
Circuit Diagram
The schematic diagram can be found HERE
Key circuit components
Connectors
RJ45 Pin Assignments
Connectors
Connector Type Function
J1 RJ45 RS485 outgoing data
J2 RJ45 RS232/RS485 incoming data
J3 RJ45 Control Signal to SSR Channels 1-4
J4 RJ45 Control Signal to SSR Channels 5-8
J5 RJ45 Control Signal to SSR Channels 9-12
J6 RJ45 Control Signal to SSR Channels 13-16
J7 RJ45 Control Signal to SSR Channels 17-20
J8 RJ45 Control Signal to SSR Channels 21-24
J9 RJ45 Control Signal to SSR Channels 25-28
J10 RJ45 Control Signal to SSR Channels 29-32
AC Power In Screw Terminals AC Power Feed
IC Chips
Integrated Circuits
Location Pins Type Function
U1 3 LF50CV Voltage Regulator
U2 6 H11AA1 Optocoupler, used to generate the Zero Cross signal for ACSSRs
U3 4 ECS-2100AX-18.432MHZ 18.432 MHz Crystal Clock Oscillator
U4 8 ST485BN RS485 Transmitter
U5 8 ST485BN RS232/RS485 Reciever
U6 14 PIC16F688 Microprocessor that controls Channels 1-8
U7 14 PIC16F688 Microprocessor that controls Channels 9-16
U8 14 PIC16F688 Microprocessor that controls Channels 17-24
U9 14 PIC16F688 Microprocessor that controls Channels 24-32
Diagnostic LEDs
NOTE: The following Diagnostic LEDs will only function when a jumper is placed on JP3 and U6 has the diagnostic firmware loaded.
Diagnostic LED Feedback
LED Firmware in U6
Diagnostic
Operational
POWER Lit whenever the voltage regulator is generating 5 VDC. Lit whenever the voltage regulator is generating 5 VDC.
HB will blink ON/OFF to indicate that the PIC is operating correctly will be ON whenever channel 2 is ON
ZC will blink ON/OFF to indicate that the Zero Cross signal is getting to the PIC correctly will be ON whenever channel 5 is ON
SD will be ON whenever the PIC is receiving data correctly will be ON whenever channel 6 is ON
FE will only be ON when the PIC has identified a Framing Error while receiving data will be ON whenever channel 7 is ON
OE will only be ON when the PIC has identified an Overrun Error while receiving data will be ON whenever channel 8 is ON
Jumpers
  • JP2 – 120 ohm termination resistor enable. Normally a shunt will be installed on JP2 when receiving RS485 data. Remove the shunt if you are experiencing problems with incoming data.
  • Main Voltage – You must provide either a jumper across the 2 horizontal jumpers to enable the board to run on 115vac, or one jumper across the 230vac jumper to allow the board to run on 230vac.
Test Points
  • GND – Ground
  • ZC – Zero Cross signal
The PICs (U6,U7 U8& U9) must be programmed with the correct firmware for the board to operate correctly. There are two types of firmware available: Operational and Diagnostic. The Operational firmware is what you need for normal board operation. The Diagnostic firmware is a troubleshooting aid to use when there are problems with the board.
Renard SS Operational Firmware:
Renard SS Diagnostic Firmware:
Instructions for using the Renard SS Diagnostic Firmware are located on this wiki page or can be downloaded in this file.
DMX Firmware:
Since there are many options available with the Renard DMX firmware it is impractical to post a dedicated Renard SS board version here. Users desiring to use DMX should get the firmware here.
Powering the REN 32
Input power requirements: An AC source. The board can be powered be either 115vac or 230vac depending on the Main Power Jumper settings.
DC power:
The Ren32 generates all the DC voltage that it requires on-board and no external DC voltage source is required.
AC Power:
The REN 32 requires AC power for generation of the DC voltage, the off board SSR (opto/triac) circuitry and for generation of the Zero Cross signal.
AC Power Handling Capability
Maximum Input Load
Since the REN 32 uses off board SSRs, the power the board can control is based on their capabilities. See the DCSSR and the ACSSR wiki for possible ssr designs to use with this board. Since the REN 32 is actually 4 banks of 8 channels you can mix and match both AC and DC SSRs in groups of 8. All channels in a bank must be the same type (AC or DC).
The board has a safety fuse for protecting the ac mains voltage on the board.
The BOM calls for a 1 amp fuse.
Hooking Up the REN 32
J1 and J2-Renard Input and Output
The two RJ45 Connectors J1&J2 near the top right of the board are used to bring data signals to and from the board. J1 on the left side is the signal input from the PC or previous Renard controller. J2 on the right side is the output to be daisy-chained to the next Renard controller. The pins on these connectors are used as follows:
Pin # RJ45 Connector
J1 Input J2 Output
1,2 GND GND
3 Pin 3 is tied to J2 Pin 3 Pin 3 is tied to J1 Pin 3
4 Data- (Rx) Data- (Tx)
5 Data+ (Rx) Data+ (Tx)
6 GND GND
7,8 Pins 7&8 are tied together to J2 Pins 7&8 Pins 7&8 are tied together to J1 Pins 7&8
Data Connections
Typical connection between RS485/DMX/Renard and Renard SS24 boards
Data Cables
Data cables for Renard SS board hookup directly to computer COMM port
PC Serial Port to REN 32
Adapter Cable
RS232 Pin #
REN 32 RJ45
PC DE9 Pin 3 RJ45 Pin 4
PC DE9 Pin 5 RJ45 Pin 5 and Pin 1 and/or Pin 2
Data cable for Renard SS board hookup using a RS232->RS485 or a USB->RS485 converter
Due to the many different types of RS232->RS485 and USB->RS485 converters available, the drawing only refers to the signals coming from the converter. Check the documentation for your converter to figure out how/where to hook up the correct wires. An example is shown here with the HXSP-2108F Adapter Hook-up
RS485 Dongle to REN 32
Adapter Cable
RS485 Pin #
REN 32 RJ45
RS485(-)/T-/D-/B/485- RJ45 Pin 4 (blue CAT5 wire)
RS485(+)/T+/D+/A/485+ RJ45-pin 5 (blue/white CAT5 wire)
GND RJ45-pins 1 & 2 (orange and orange/white CAT5 wires)
Data cable for Renard SS board hookup in a DMX environment
DMX using XLR Connectors
Adapter Cable
DMX XLR Pin #
REN 32 RJ45
XLR connector Pin 1 (GND) RJ45-pin 1 and/or pin 2
XLR connector pin 2 (Data-) RJ45-pin 4
XLR connector pin 3 (Data+) RJ45-pin 5
DMX using RJ45 Connectors
Adapter Cable
DMX RJ45 Pin #
REN 32 RJ45
RJ45 connector pin 1 (Data+) RJ45-pin 5
RJ45 connector pin 2 (Data-) RJ45-pin 4
RJ45 connector pins 7 & 8 (GND) RJ45-pins 1 & 2
Data cable for Renard SS board hookup to other Renard boards
Generally only a regular straight-thru CAT5 cable is required to connect Renard SS boards to other Renard boards.
Cable Lengths
AC Power Connection
AC Power Connection
The AC power source is connected to the two screw terminals on the left side of the board.
THE CORRECT POWER JUMPERS MUST BE INSTALLED FOR THE CORRECT LINE VOLTAGE BEING SUPPLIED TO THE BOARD!!!
Power Connections
Pin # Input Voltage
115VAC 230VAC
"AC"
Top
Neutral
(White Wire)
Hot Wire
"IN"
Bottom
Hot
(Black Wire)
Hot Wire
SSR Connections
Connecting SSRs to the REN 32
The REN 32 provides control signals to external Solid State Relays (SSRs) to switch power on/off and to dim the lights connected to the SSRs.
Output Jack Pin Assignments
Pin #
Signal
1 +5VDC
2 First Output Channel
3 Not Connected
4 Second Output Channel
5 Not Connected
6 Third Output Channel
7 Signal Ground
6 Fourth Output Channel
Each of the 8 output jacks control 4 channels each.
Output Jack Channel Assignments
Jack #
Channels
J3 1-4
J4 5-8
J5 9-12
J6 13-16
J7 17-20
J8 21-24
J9 25-28
J10 29-32
Configuring the jumpers on Renard SS boards
JP1 & JP2 Configuraton
The configuration of JP1 and JP2 depends on the type of communication being used:
RS-232 Communication (direct connect to PC)
  • JP1 installed
  • JP2 not installed
Reminder: This only applies to the first Renard SS board connected to the PC. The output of a Renard SS board to the next board is RS-485.
RS-485 Communication (output of a Renard board or output from a RS-485 adapter/converter)
  • JP1 not installed
  • JP2 installed (try removing if data communication issues are encountered)
JP3 Configuraton
  • Installed when running the Diagnostics Firmware
  • Normally not installed when running the Operational Firmware. But can be left installed if you don’t mind seeing the on-board LEDs responding with the associated channels.
Computer Setup
VIXEN Settings
  • Protocol Version: 1
  • Parity: None
  • Data bits: 8
  • Stop bits: One
If you are unsure that you have built your hardware correctly, you should follow the procedures contained in the REN 32 Beginners Setup Guide. These procedures will guide you through the steps to help setup the hardware for the first time.
If you encounter any problems with your REN 32, you can go to the Troubleshooting Guide For The REN 32. The troubleshooting guide contains a methodical process to try to isolate problems/malfunctions and gives suggestions of what to do to fix them.
Beginners Setup Guide The REN 32
Assembly Instructions For The REN 32
Troubleshooting Guide The REN 32
Board Availability Information
Renard Main Page
Renard Firmware
Part Substitutions
VIXEN
Glossary of DIYC Terms
Electronic Symbols
