SSRneon TA-200 Versions
(Redirected from SSRneon TA-200)
Version G2
Version G2
Two versions that fit in the TA-200 Enclosure
The SSRneon-G2 is available in two versions, the SSRneon-G2 and the SSRneon-G2-LED.
Both of these designs share similar layouts and both have the neon bulb indicators for extra safety.
The SSRneon-G2 was available as both a production board and as a home-etchable board.
The SSRneon-G2-LED is only available as a two sided production board. There is no home etch layout available.
SSRneon-G2 bare PCB
SSRneon-G2-LED bare PCB
Safety Features
ne-2E
ne-2E
1. Dual Neon bulbs that indicate the presence of AC Voltage on both sides of the Fuse !
terminal block
terminal block
heat sink
heat sink
TA-200
TA-200
Order your own boards
The Gerbers for the SSRneon-G2 are found at this link: Zip File containing the SSRneon G2 Gerber files
Home Etch
copper
copper
Fuse Rating
fuse
fuse
A Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual TRIAC (channel), then you can ramp up to as high as a 7 amp fuse. However, once you move above 1 amp through any single TRIAC (channel), you should put a heat sink on the TRIAC(s). This does not mean you can run 7 amps through a single TRIAC (channel). A single TRIAC can handle about 1.5 amps, perhaps 1.75 max. You will notice that the copper traces that connect to any one TRIAC are no where near the size of the main AC copper trace. So, just because the TRIAC you use may be rated for 3 or 4 or more amps doesn't mean the SSRneon can safely drive it at that amperage.
Note regarding resistors. You usually want to purchase resistors from Mouser in quantities of 100 of a specific value. You usually can get 100 resistors for the same price of 20 individual resistors. (You will eventually use them !)
SSRneon-G2 BOM for 120VAC Operation:
QTY  Silkscreen       Mouser #:           Description
2                     606-A9A            Neon Lamp 65VAC .7mA NE-2E
1                     571-5556416-1      Modular Jacks 8 PCB TOP ENTRY marked RJ45
4                        -BTA06-600CW    Triacs .........
4                     511-BTA04-700T     Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4
2                     534-3517           Fuse Clips and Holders PC FUSE CLIP 5 MM
1                     604-WP7104IT       LED Standard HI EFF RED TRANS marked LED
5   R1,R2,R3,R4,R11   660-CF1/4C681J     1/4Watt Axial Carbon Film Resistors 680ohms 5% marked
4                     660-CF1/4C181J     1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8
2                     660-CF1/4C104J     1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10,
4                     859-MOC3023        Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4
4                     571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                                         also marked U1, U2, U3 and U4
5                     571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
Additions for the SSRneon-G2-LED:
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay
240VAC Operation
FireGod
Here is a picture of a completed SSRneon-G2-LED:
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
Controller Output Pinout
Pin Number Connection
1 +5v DC Power
2 Channel 1 Signal
3 reserved
4 Channel 2 Signal
5 reserved
6 Channel 3 Signal
7 Ground
8 Channel 4 Signal
Version G2
Version G2
Original SSRneon
