Renard PX1 Pixel Controller
General
Features
- Some Design Details:
- Supports WS2811 strings at with either 400KHz or 800 KHz data rate
Total Number of Pixels Capable for a given Baud Rate/Refresh Interval* | |||
Baud Rate | Refresh Interval | ||
100 ms | 50 ms | 25 ms | |
460800* | 1528 | 764 | 382 |
230400* | 764 | 382 | 191 |
115200 | 382 | 191 | 95 |
57600 | 191 | 95 | 47 |
38400 | 127 | 63 | 31 |
19200 | 63 | 31 | 15 |
Typical Pixels require power injection every 50 pixels. The Renard PX1 only supports up to 50 Pixels directly powered from the controller. If you use more then 50 Pixels (or if the cable is too long for the wire gauge), you must provide an off-board fused power source to provide power injection downstream.
NEEDS TO BE UPDATED, THIS WAS AN EARLIER DESIGN This is a preliminary Renard PX1 schematic. RevE sch.PNG Schematic
PCB Layout
BOM - Bill Of Materials
Part | Mouser PN | Description | Qty |
R6 | 291-120-RC | Carbon Film Resistors - Through Hole 120ohms 0.05 | 1 |
R5,R7 | 299-1K-RC | Carbon Film Resistors - Through Hole 1Kohms 5% | 2 |
R1,R2 | 299-27K-RC | Carbon Film Resistors - Through Hole 27Kohms 0.05 | 2 |
R4 | 264-330-RC | Resistor Network, 330 Ohm, Bussed, 6-pin | 1 |
R3,R8 | 299-47-RC | Carbon Film Resistors - Through Hole 47ohms 0.05 | 2 |
C2,C3 | 810-FK28X5R1C105K | Multilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10% | 2 |
C1 | 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R | 1 |
D1 | 78-1N5239B | Diode, Zener 9.1V .5W | 1 |
D2 | 78-1N5229B | Diode, Zener 4.3V .5W | 1 |
D3,D4 | 604-WP710A10YT | LED, 3mm Yellow | 2 |
D5,D6 | 604-WP710A10GT | LED, 3mm Green | 2 |
IC1 | 595-SN65LBC179PE4 | Buffers & Line Drivers | 1 |
IC2 | 579-PIC16F1825-I/P | Microcontroller | 1 |
IC3 | 926-2950CZ-5.0/NOPB | LDO 5.0/100mA | 1 |
U1 | 571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 1 |
U2 | 571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 1 |
J5,J6 | 571-5556416-1 | Jack, Modular RJ45 PCB Mount Top Entry | 2 |
J4 | 538-22-03-2021 | Headers & Wire Housings VERT PCB HDR 2P TIN PLATING | 1 |
J3 | 649-77313-122-10LF | Headers & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH | 1 |
J2 | 538-22-03-2061 | Headers & Wire Housings VERT PCB HDR 6P TIN PLATING | 1 |
J1,J7 | 538-22-03-2031 | Headers & Wire Housings VERT PCB HDR 3P TIN PLATING | 2 |
J8 | 571-2828372 | Fixed Terminal Blocks 5.08MM PCB MOUNT 2P | 1 |
Jumpers | 151-8000-E | Headers & Wire Housings MINI JUMPER GF 6.0MM OPEN TYPE BLACK | 7 |
J9 | 538-39501-6004 | Pluggable Terminal Blocks 3.5MM EURO HEADER VE HEADER VERT GRN 4CKT | 1 |
Pixel Connector | 538-39503-2004 | Pluggable Terminal Blocks 3.50MM EURO PLUG VER UG VERT RWE BLK 4CKT | 1 |
Fuse | 504-ATM-5 | Fuses 5A 32Vdc 1kA IR Tan | 1 |
Fuse Holder | 534-3544-2 | Fuse Holder | 1 |
Assembly Instructions
- Configure Jumpers
- □ Install Resistors
- □ Install Capacitors
- □ Install Diodes
- □ Install IC Sockets
The notch faces right. - □ U2 - 14 pin socket. The socket has a notch on one end and the notch must be installed to match the direction on the silkscreen.
The Notch faces right.
- □ Install LEDs
- □ Install Voltage Regulator
- □ Install Fuse Holder
- □ Install Connectors
- □ Install RJ45 Jacks
- □ Install Fuse
- □ Install ICs
The IC has a notch on one end and the notch must be installed to match the direction on the silkscreen. - □ IC2 - PIC16F1825-I/P PIC microprocessor. The IC is polarized and it has to be installed with the correct orientation.
Configure Jumpers
Install a shunt (jumper) across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input. Otherwise, don't install any shunt here
J3- 2x5 Options Connector
J4- Options Programing
Do not install any jumper here until instructed to do so.TBD
J7- Voltage Selector
Program PIC
Do not install any shunt in J4 while programming the PIC.
J2-ICSP Programming Header
J2 ICSP Pin Assignments | ||
Pin # | ||
Signal | ||
1 | VPP/MCLR | |
2 | VDD Target | |
3 | VSS (Ground) | |
4 | ICSPDAT/PGD | |
5 | ICSPCLK/PGC | |
6 | N/C |
Connections
Serial Data Connector Pin Assignments | ||
Pin # | RJ45 Connector | |
J5 Input | J6 Output | |
1,2 | GND | GND |
3 | NC | NC |
4 | Data- (Rx) | Data- (Tx) |
5 | Data+ (Rx) | Data+ (Tx) |
6,7,8 | NC | NC |
J8-Pixel Power Input
J8 Power Input | ||
Pin # | ||
Voltage | ||
1 (square pad on left) | GND (V-) | |
2 (round pad on right) | V+ |
J9 - Output to Pixels
J9 Pixel Output Pin Assignments | ||
Pin # | ||
Signal | ||
1 | GND (V-) | |
2 | Clock (C) | |
3 | Data (D) | |
4 | V+ |
Indicator LEDs
Attn
Rx
FE
Pwr
- RGB Order: Allows to make corrections for strings where the pixels respond in a different color order UNDER DEVELOPMENT
- Grouping: Allows you to treat multiple pixel as one pixel, cutting down on the number of channels used. UNDER DEVELOPMENT
Enclosure
Different_Styles_of_Pixels
Dumb_RGB_or_Intelligent_Pixels??
Things_You_Will_Need_To_Get_Started_With_Pixels
Pixel_Wiring_Colors
