- Pixel Controllers
- Dumb RGB Controllers.
- E1.31 (DMX over Ethernet)
- Advanced Features
- Etc.
PIXEL CONTROLLERS
HolidayCoro
Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link | Price | Manual/Videos | Note |
PixLite 4 | 2,720 | 16 UniCast 16 MultiCast |
WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 USC6909,UCS6912,SM16716,MBI6020 |
Product Link | Assembled $129.99 | General Setup Video LOR S3 Setup Video Manual |
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor | |
PixLite 16 | 16,320 | 32 UniCast 32 MultiCast |
File:HolidayCoro-621.jpg | Product Link | Assembled $219.99 | General Setup Video LOR S3 Setup Video Manual |
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor |
SanDevices
Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | Max Channels | DMX Universes per Output | Image | Link | Price | Manual | Note |
E6804-4 | 2040 | 7Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 4 Fused (1x4 Electrical, 4x1 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $99, Full Kit: Price $69 Presale | Owner's Assembly | Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement | |
PS-1 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Turnkey System: $399 | Owner's | Assembled E682 with power supply in an Enclosure | |
E682-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $180, Full Kit: Price $109 | Owner's Assembly | To be released shortly | |
E682-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Assembled/Tested: $180, Full Kit: Price $109 | Owner's Assembly | Original E682, Before Firmware Upgrade | |
E681-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | No Longer Available | Owner's Assembly | Firmware To be released shortly, requires UP1 upgrade | |
E681-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | No Longer Available | Owner's Assembly | Original E681, with Firmware Upgrade and UP1 upgrade | |
E681-4 | 680 | 4Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 2040 | Up to 4 | link | No Longer Available | Owner's Assembly | Original E681, without Firmware Upgrade and without UP1 upgrade | |
E680-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | To be released shortly, requires UP1 upgrade | |
E680-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | Original E680, with Firmware Upgrade and UP1 upgrade | |
E680-4 | 680 | 4Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 2040 | Up to 4 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | Original E680, without Firmware Upgrade and without UP1 upgrade |
Joshua 1 Systems (J1SYS)
ECG-P12R | 2040 | 12Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 12 Fused (2x6 Electrical, 3x4 Logical) | 6120 | 1 | link | Assembled Board: $175 | Owner's Notes | ||
ECG-PIXAD8 | 1360 | 8Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 8 Fused (2x4 Electrical, 2x4 Logical) | 4080 | 1 | link | Assembled Board: $155 | Owner's | ||
ECG-P2 | 1360 | 8Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (2x1 Electrical, 2x1 Logical) | 4080 | 4 | link | Assembled Board: $68, Assembled Board w/case: $77 | Owner's |
Stellascapes
E16-II Green | 672 | 6Unicast | Stella-green | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $1296 | 16 Character LCD Display for diagnostics and identification information. | ||
E16-II Commercial | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $1995 | With power supply and 16 400mm "tails" with waterproof screw up connectors | ||
E16-II Pro | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $?? | With power supply and Neutrik XLR, power and ethernet chasis connectors | ||
E2 | 170 | 1Unicast | Stella-black | 2 ? | 512 | ? | link | Assembled Board: $?? | With power supply,operates on low voltage DC (12-48V) |
DMX512 to SPI
HolidayCoro
Model | Max Pixels | DMX Channels | Pixels Supported | Output Connectors | Image | Link | Price | Note |
EasyPix | 170 | 512 | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803 |
Product Link | $39.99 | Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences | |
TinyPix | 170 | 512 | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803 |
Product Link | $34.99 | Null pixels, Reverse order, built-in sequences |
DCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $53 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels | ||
uDCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $42, Assembled Board w/Case: $48 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels |
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL
Onumen
RPM
Stellascapes
- T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
- ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
USB to DMX512 Output
- Enttec Open DMX USB
- Enttec DMX USB Pro
- RPM DIY USB to DMX Adaptor
- RJ's LYNX DMX DONGLE
FTDI drivers for dongles:
- FTDI VCP Drivers
Manufacturer | Model | Pre-built | DC Voltage | Channels | Channel Current | Total Current | Protocol(s) | Total Price | Per Ch Price |
Light-O-Rama | CMB16D | Yes | 5V - 60V | 16 | 4A | 20A per 8 Ch | LOR, DMX | $119.95 | $7.49 |
Light-O-Rama | CMB16D-QC | Yes | 5V - 60V | 16 | 4A | 20A per 8 Ch | LOR, DMX | $99.95 | $6.24 |
TigerDMX | TigerDMX48 | Yes | 9V - 55V | 48 | 2.5A | 30A per 24 Ch | DMX | $145.00 | $3.02 |
TigerDMX | TigerDMX120LC | Yes | 12V - 36V | 120 | 100mA | DMX | $125.00 | $1.04 | |
AVD | DC48 | Yes | 12V - 36V | 48 | 2A | 20A per 24 Ch | DMX | $199.00 | $4.15 |
AVD | DC24 | Yes | 12V - 36V | 24 | 2A | 15A per 12 Ch | DMX | $129.00 | $5.38 |
Audiolight Intl | HD-714 [1] [2] | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
Audiolight Intl | HD-712 [3] [4] | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
Leynew | LN-DMXMODEL-3CH-LV12 Bare Leads CAT5 Input [5] | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
EUChips | PX24506 | Yes | 12V - 24V | 3 | 3A | 9A | DMX | $22.32 | $7.44 |
wjohn | DMX3 | No | 9-35vdc | 3 | 2A per Chn | up to 6A | DMX | $9.00 | $3.00 |
wjohn | DMX16DCSSR | No | 12-24vdc | 16 | 2A per Chn | up to 10A | DMX | $48.00 | $3.00 |
wjohn | REN64 | No | 9-35vdc | 64 | 2A per Chn | up to 7A per SSR | RS232/485, DMX | $67.50 | $1.05 |
Renard | Ren48LSD | No | 5,9-24vdc | 48 | 400mA | 9.6A x 2 | RS232/485, DMX | $44.66 | $0.93 |
DIYLEDExpress | Ren24DC | Built or Kit | 5,7-24vdc | 24 | 4A | 30A x 2 | RS232/485, DMX | $72.10 | $3 |
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
