ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/9/95/Pops_tiny.jpg)
![Version V2](/wiki/images/3/30/Pops_board.jpg)
![Version V2](/wiki/images/2/29/Pixel_Pops_Tiny_Picture_2.jpg)
What is a Pixel Stick?
These controllers have two basic characteristics:
Click Here:
Pixel Pops & Pixel Pops Tiny
Pops-O-Matic Info
![small](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
These are available for a total of 34 cents from Tayda Electronics.
Fuse Holder
5A Fuse
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
BOM UPDATE:
DIYC member mattd has done some research and created a BOM with some alternate manufacturers.
![small](/wiki/images/b/b5/Pixel_pops_both.jpg)
Wiring The ESPixel Pops
![small](/wiki/images/5/57/Pixel_pops_tiny_built_by_Steven_Dill.jpg)
![small](/wiki/images/e/e3/Pixel_pops_tiny_with_radio_built_by_Steven_Dill.jpg)
A Key Point Regarding Power
A 3D printed Mount for your Pixel Pops controller
A small Item that you can mount in a cable guard box or other waterproof enclosure
The .stl file is available for free on thingiverse at this link:
Thingiverse link for Pixel Pops mount
Programming the ESP-01 Module
As of 11/21/2019, the current release by Shelby that implements dimming control and other features.
As of 1/14/2020 Version 3.1 is a Major Update Many features including direct support of Webmos & NodeMCU ESP modules.
You can find it here: https://github.com/forkineye/ESPixelStick/releases Pixel Stick Software]
Upload the firmware
Download the latest Firmware.
Install Java JRE.
William Napier crated these in a few hours as a novice solderer. All worked fine on the first try !
