ESPixel Stick & ESPixel Pops
What is a Pixel Stick?
These controllers have two basic characteristics:
1.  They control pixel based LED lights
2.  They are wireless in terms of their 'data' transfer
As a result, there is one common firmware thread that works on all of the ESP-01 based DIYC pixel sticks.
Click Here:
The ESPixel Pops is the most basic of the Pixel Stick designs.  It is a fully through hole PCB with no smd(surface mount) components.  Therefore, it is easily built by most anyone with basic soldering skills.
From a software perspective, it is an E1.31 sACN (Streaming ACN) pixel controller that connects over a standard (802.11g/n) WiFi network.  The firmware is open source and developed in the ESP8266 Arduino environment.  It provides a web based configuration front-end and currently supports WS2811 / WS2812 pixels. (3-wire pixels)
Pixel Pops & Pixel Pops Tiny
Pops-O-Matic Info
7.  The board is small enough to fit inside a 1" thinwall PCB pipe with the PCB measuring only 24.18x33.32 mm and 24.18x24.61 mm for the tiny version.  This type of pipe is listed as SDR-21.
The board is professionally manufactured with 1oz copper and the holes are through plated.  This makes for easy and more error free soldering.
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
These are available for a total of 34 cents from Tayda Electronics.
Fuse Holder
5A Fuse
- D1 - One diode.  This must be: 1N4148
- ESP-01 - One female socket header, 2 rows of pins, 4 pins in each row.  This functions as the socket where you plug the ESP8266 module into
- One six pin header.  Readily available 2.54mm (.1") pitch. (distance between the pins)
- One tactile switch.  6mm x 6mm. Also readily available. These often have choices as to the height of the push button.
- R1 & R2 - Two 1/8W or 1/4W carbon film or metal film resistors.  330 Ohms.
- C2 - One polarized Electrolytic capacitor.  Any value from 10uF to 220uF will do. 10V or above. Pay special attention to the diameter and spacing of the leads. The diameter can be no more than 5mm and the leads should be spaced at 2mm.
- C1 - One MLCC monolithic capacitor. 2.54mm lead spacing.  0.1uF, any voltage over 24V. (Usually these are 50V rated) These are typically the 'yellow blob' style capacitors, verses the ones that are shaped like a flat disk.  These do NOT have a + & - indication, unlike the electrolitic capacitor noted above.
- IC1 - One 5.0v voltage regulator.  This part is optional and should only be installed if you are planning to drive 12v pixels.
- Q1 - One Mosfet.  This must be: 2N7000 or ZVN3306A, which has a T0-92-3 style package
- A five pin screw terminal header.  5 positions total.  This connection should have 3.81mm spacing of the mounting pins.
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
BOM UPDATE:
DIYC member mattd has done some research and created a BOM with some alternate manufacturers.
The ESPixel Pops is a pretty easy build.  The real trick is deciding how you plan to power your pixels as that will affect what you do with the board wiring.
 This module does not care if you are running 5V or 12V pixels.  So, you can connect 5V or 12V to the board.
The board has a place for a second voltage regulator.  This is to accommodate 12V pixels.
This is location IC1 on the board.  This is a spot for either a 5V regulator or a wire jumper.
Wiring The ESPixel Pops
A Key Point Regarding Power
So, if you run 5V pixels, you must have a 5V PS.  Same is true for 12V pixels.
A 3D printed Mount for your Pixel Pops controller
A small Item that you can mount in a cable guard box or other waterproof enclosure
The .stl file is available for free on thingiverse at this link:
Thingiverse link for Pixel Pops mount
Programming the ESP-01 Module
For example, the Pops-O-Matic programming board is a dedicated ESP-01 programming board.  Others are also available.
As of 11/21/2019, the current release by Shelby that implements dimming control and other features.
As of 1/14/2020  Version 3.1 is a Major Update  Many features including direct support of Webmos & NodeMCU ESP modules.
You can find it here: https://github.com/forkineye/ESPixelStick/releases Pixel Stick Software]
Here is a posting by PCpackrat that describes his experience:  NOTE:  the most current info is at the github webpage noted below...
Upload the firmware
Download the latest Firmware.
Install Java JRE.
William Napier crated these in a few hours as a novice solderer.  All worked fine on the first try !
