Renard 24LV
Revision 1.0 Board (2008 Co-Op #1)
Layout
COOP PCB V1.0
Co-Op Board 1.0 Assembly Instructions
Currently in-process!
Board Usage
To run a single high-current LED (for an application such as strobeing)
On the board, there are jumpers next to each set of RJ45 jacks. These allow the + voltage on pins 1,3,5,7. By default, it is only on pin 1.
To run the Co-Op SSRs
To run the Co-Op SSRs, a CAT5 cable would be connected to one of the output jacks and run to the SSR input jack.
To run a small string of LED lights
One possible application would be to drive arrays of individual LED strings. With the ULN2803, it is capable of driving up to 500ma per output. (Reccommend using an external +5V power source for this) I would suggest that you can probably run up to 20, 20ma LED's per output, but would reccommend running no more than 100 LED's at once with an external power supply.
In this case, it is using a 5v output from the Ren24 LV, and directly driving the LED's from output of the ULN2803.
This info is based on the LED calculator from linear1.org http://led.linear1.org/led.wiz
Testing the v 1.0 Co-Op Board
There are 7 test points located on the board (TP1 to TP7)
TP1: +5v TP2: GND TP3: +12v TP4: 12vac TP5: 12vac TP6: RS485A / RJ45 Pin 5 TP7: RS485B / RJ45 Pin 4
Design Notes for v 1.0 Co-Op Board
Renard 24 Jumper Settings and Options
Transformer On/Off: If on, the transformer recieves power from the left power input.
All Renard Firmware is located Renard_Firmware This board REQUIRES the POSITIVE OUTPUT firmware option.
1 Ren24 Lv v1.0 Renard 24-Port LV PCB Board Specific Parts: PLEASE SEE BELOW FOR v3.3 BOARD 595-SN75176BP 2 511-L7805CV 1 '''LM7805 Voltage Regulator''' 821-DB102G 1 '''subsitute part 512-DF01M''' 532-7136DG 1 271-27K-RC 3 '''27k ohm 1/4 watt resistor''' 271-1K-RC 4 '''1k ohm 1/4 watt resistor''' 271-120-RC 1 '''120ohm 1/4 watt resistor''' 625-1N4001-E3 1 78-1N5239B 2 838-3FD-320 1 '''Larger Transformer Reccommended for LV/LED use part 838-3FD-420''' 782-H11AA1 1 520-TCF1843-X 1 140-HTRL25V1000-RC 1 140-HTRL25V10-RC 1 534-3517 4 504-GMA-15 2 Parts from the Common Parts List: (Common parts are the parts that are not unique to the Ren24, and may also be used in other designs) PLEASE SEE BELOW FOR v3.3 BOARD 579-PIC16F688-I/P 3 '''Microchip PIC 16F1688''' 604-WP63ID 4 '''Red T1 3/4 LED, or any 10-30ma LED''' 604-WP1503GD 1 '''Green T1 3/4 LED or any 10-30ma LED''' 271-680-RC 5 '''680ohm 1/4 watt resistor''' 581-SA105E104MAR 5 '''.10 uF Ceramic Capacitor''' 571-41032390 1 '''.100 three pin header(4 needed) Part specified is a 40 pin, cut off size that is needed.''' 571-3828115 8 '''.100 Shunt (4 needed) You may also "steal" these off of old computer parts.''' 571-1-390261-2 2 '''8 pin DIP socket''' 571-1-390261-3 3 '''14 pin DIP socket''' 571-3902611 2 '''Optional 6 Pin Socket for Optocoupler & H11AA1''' 571-5564161 2 '''RJ45 Sockets (2 needed) orientation doesn't matter. Specified part is same as the Ren64''' 571-7969495 1 '''five pin header to jumper both hot sides REPLACES 571-7969494''' 511-ULN2803A 4 '''ULN2803 Darlington Array''' Optional Parts for The Board: 12VAC Operation 571-41032390 1 '''.100 two pin header(2 needed)''' 571-3828115 4 '''.100 Shunt (2 needed) You may also "steal" these off of old computer parts.''' 838-3FD-320 0 '''Transformer is ELIMINATED from the board in this option'''
PC to Renard24 LV Cable
PC DB9 Pin 3 to RJ45-pin 4 PC DB9 Pin 5 to RJ45-pins 1,2,5 (pins 1 and 5 are required, pin 2 is optional).
Female DB9 connector as if you were looking into the end of it from the outside.
