Renard 64XC
The Board
Circuit Diagram
- Key circuit components
- Connectors
- J3 – RS485 outgoing data
- Connectors
- IC Chips
- IC Chips
- Resistors
- Resistors
- LEDs
- LEDs
- When U7 is programmed with the Diagnostic Firmware:
- Other Components
- U1 – Voltage Regulator
- Other Components
- Jumpers
- Jumpers
- Test Points
- GND – Ground
- ZC – Zero Cross signal
- Test Points
Bill of Materials
Note: This BOM does not include a transformer, power cords or connectors for the primary side of the transformer. PCB 1 TBA Renard 64-Port PCB Resistors 2 299-750-RC 750 Resistor, 1/8 W, Axial R1,R2 1 660-MF1/4DCT52R1200F 120 Resistor, 1/4 W, Axial R3 3 299-27K-RC 27K Resistor, 1/8 W, Axial (RS485 pull) R5,R8,R14 2 299-1K-RC 1K Resistor, 1/8 W, Axial (RS485 series) R4,R7 1 299-330-RC 330 Resistor, 1/8 W, Axial (for power LED) R19 Capacitors 1 667-ECA-1CM682 6800 uF, 16V Radial-Lead Elect. Cap C1 8 80-C322C104K5R 0.1 uF Radial-lead Ceramic Capacitor C3-C10 1 647-UVR1C470MDD 47 uF, 16V Radial-Lead Elect. Cap C2 Diodes 4 625-1N5817-E3 Schottky Diode (20V, 1A) D1-D4 1 78-1N5229B 4.3v 0.5w Zener D5 1 78-1N5239B 9.1v 0.5w Zener D6 1 604-WP7104GT T1 Green LED D7 Connectors 2 571-5520251-4 AMP Modular Jacks, Right Angle J3, J4 16 571-5556416-1 AMP Modular Jacks, Vertical PCB mount J5-16, J18-21 1 636-182-009-213R531 *Norcomp DE9 Female Rt Angle D-sub Conn J22 8 575-199314 14 Pin Low Profile IC Socket U7-U14 1 538-22-03-2021 Molex PCB Header 2-pin JP1 1 151-8000 2-Pin Shunt JP1 2 534-4902 Male Sturdi-mount Terminal Tab1, Tab2 2 159-2215 Vinyl Insulated Couplers (Female) Tab1, Tab2 1 538-39890-0302 *2 Position Terminal (replaces Tab1/2) 2 571-1-390261-2 *8 Pin Economy IC Socket U4, U5 1 571-1-390261-1 *6 Pin Ecomony IC Socket U6 ICs 1 511-L4940V5 Regulator, LDO, 5V, 1.5A U1 1 532-577102B00 *Heat Sink U1 2 511-ST485BN RS485 Connectors U4,U5 1 782-H11AA1 Optoisolator U6 8 579-PIC16F688-I/P PIC16F688, DIP14, Industrial Temp U7-14 Oscillator 1 520-TCH1843-X Oscillator, 18.432 MHz, 5V, 8-DIP U3 Optional (if per/port LEDs are desired but these are also used as the Diagnostic LEDs as well...STRONGLY SUGGESTED) 64 859-LTL-403G *LEDs, Rectangular, Green 8 652-4608X-1LF-680 *Resistor Network, 680 Ohm, 8-Pin, Bussed R10-13, R20-23 8 299-680-RC *Resistor, 680 Ohm, 1/8W R15-18, R24-27 *Items marked (*) are optional and up to the user. However, they are strongly encouraged.
BOM For Mouser
This link, Mouser REN64XC BOM , is to a live REN64XC bill of materials already loaded into Mouser's system. You just need to put it in your shopping cart. I contains all the optional components listed as well as a 115VAC-->6.3VAC transformer. This is the recommended configuration.
2008/01/21 PJS DE9 connector (J22) added to BOM 2008/01/25 PJS changed value of R1, R2 to 750 Ohm (was improperly calculated for 6.3VAC input). 2008/02/18 PJS changed value of C1 2010/08/13 JCF changed part number of C1 due to end of life.
Powering the Renard 64
DC power:
AC Power:
- If you do not have 120VAC power, then you may have a larger challenge. A cost effective transformer from 220VAC to 6.3VAC has not been located. There are options but you should get some expert assistance from forums members. Careful selection of resistor replacements with special care to the overall maximum input voltage is required and each case is special.
Hooking Up the Renard 64
Data Connections
![](/wiki/images/4/45/RenardRS232HookUp.jpg)
![](/wiki/images/6/6b/RenardRS232Hookup2.jpg)
Data Cables
![](/wiki/images/thumb/0/01/DE9toDE9_Renard.gif/900px-DE9toDE9_Renard.gif)
![](/wiki/images/0/05/DE9toRJ45_Renard.gif)
- Data cable for Renard 65 board hookup using a RS232->RS485 converter or DMX Adapter
![](/wiki/images/8/87/RS485toRJ45_Renard.gif)
RS485 Adapter Pinouts RS485(-) Signal to RJ45-pin 4 RS485(+) Signal to RJ45-pin 5
DMX via XLR Connectors - Pinouts XLR connector pin 1 (GND) to RJ45-pin 1 and/or pin 2 XLR connector pin 2 (Data-) to RJ45-pin 4 XLR connector pin 3 (Data+) to RJ45-pin 5 DMX via RJ45 Connectors - Pinouts RJ45 connector pin 1 (Data+) to RJ45-pin 5 RJ45 connector pin 2 (Data-) to RJ45-pin 4 RJ45 connector pins 7 & 8 (GND) to RJ45-pins 1 & 2
Cable Lengths
![](/wiki/images/e/ec/RenardDaisyChain.jpg)
Computer Setup
- VIXEN Settings
- Protocol Version: 1
- Parity: None
- Data bits: 8
- Stop bits: One
- If you are unsure that you have built your hardware correctly, you should follow the procedures contained in the Renard SS24 Beginners Setup Guide. Although this guide was not specific to the Renard 64, these procedures will guide you through the general steps to help setup the hardware for the first time.
- If you encounter any problems with your Renard REN64, you can go to the Troubleshooting Guide The Renard SS24. Once again, this is not specific to the REN64, but you can get valuable information from the SS series. The troubleshooting guide contains a methodical process to try to isolate problems/malfunctions and gives suggestions of what to do to fix them.
