Vastelec FM02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.
However, it is not a complete unit ready for use. Instead, it bridges the gap between an out-of-the-box solution, and a build-your-own unit that starts with a bare PCB and a bag of parts.
- Power. A regulated 12v DC power supply is needed. 250ma is enough current.
About VAST Electronics
Detailed Board Dimensions
This is one board of a two board set
Antenna
