Vastelec FM02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.
However, it is not a complete unit ready for use. Instead, it bridges the gap between an out-of-the-box solution, and a build-your-own unit that starts with a bare PCB and a bag of parts.
- Power. A regulated 12v DC power supply is needed. 250ma is enough current.
About VAST Electronics
DO NOT apply anything GREATER then REGULATED 12V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit. These are about $5 online. <\p>
Detailed Board Dimensions
This is one board of a two board set
<\p> The second board has the same physical outline dimensions. It also lines up with the 4 corner mounting holes.
<\p>
Antenna
