Vastelec FM02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.
- Power. A regulated 12v DC power supply is needed. 250ma is enough current.
About VAST Electronics
Detailed Board Dimensions
Antenna
