Vastelec FM02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display. It comes just as shown in the picture shown above.
About VAST Electronics
Detailed Board Dimensions
Antenna
