Vastelec FM02
Revision as of 02:05, 30 September 2011 by Ukewarrior (talk | contribs) (Setup)
FM-02
FM-02
FM-02b
About VAST Electronics
Vendor's Website
Data Sheet
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
How to Make a Dipole Antenna
What Frequency to Use
This is real simple, go to this website and find a frequency that is unused. If there are no unused frequency's, then pick one that is not very powerful and get your radio out and check it out. If you can't pick it up at your house, odds are no one will complain when you start broadcasting on that frequency.
http://www.radio-locator.com/
Where can I get one of these wonderful devices ?
