Vastelec FM02
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Many folks will experience some HUM in the transmitted audio. This is normal. The good news is that you should be able to eliminate this hum with the use of a Ferrite Bead. (See Audio Section below for poor audio quality problems)
Audio
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
Ways to inprove the sound quality for Advanced Users
Analysis of previous "fixes":
These previous "fixes" noted within this thread by operating the unit at a reduced voltage only drops the mean voltage feeding the chip and thus drops the chips ability to function correctly. By turning down the operating voltage, that is one way to reduce that hissing pilot level, but your also reducing the correct operating voltage for not just the FM chip, but the microprocessor, the PLL, the display, the final RF amp, the whole thing, not to mention reduced range and added distortions in the audio paths within the TX and FM chip itself.
