Vastelec FM02
The FM02 is a two board FM transmitter.  It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.  It comes just as shown in the picture above.
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adapter
			RPM DMX4 SSR
			RPM DMX16 SSR
			RPM DMX8 DC SSR
			RPM DMX16 DC SSR
Do you have a HUM ?
Audio
Schematic and PCB layout
Detailed Board Dimensions
Antenna
 You will need to buy or make an antenna.  There are MANY different designs for antennas.  A large number of DIYers have made a type of antenna known as a dipole.  This is an easy to make antenna that will serve almost anyone's needs.  Here is a link to a pdf with instructions to make your own:
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
