Vastelec FM02
The FM02 is a two board FM transmitter.  It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.  It comes just as shown in the picture above.
Pictures of FM02's in enclosures
Each FM02 installation is unique !
A gallery of pictures showing various FM02 installations is available.
Click Here to see many FM02 installations: FM02_Galleryx Link currently turned off while the page is built.
Do you have a HUM ?
Audio
Schematic and PCB layout
Detailed Board Dimensions
Antenna
 You will need to buy or make an antenna.  There are MANY different designs for antennas.  A large number of DIYers have made a type of antenna known as a dipole.  This is an easy to make antenna that will serve almost anyone's needs.  Here is a link to a pdf with instructions to make your own:
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
