Creating a PixelPlane
Current as of Version 12K.
What is a PixelPlane?
How to Create a PixelPlane
![](/wiki/images/thumb/0/01/HLS_PixelPlane_SpecifyYourPixelPlane.png/300px-HLS_PixelPlane_SpecifyYourPixelPlane.png)
![](/wiki/images/thumb/d/de/HLS_PixelPlane_PixelPlaneObject.png/300px-HLS_PixelPlane_PixelPlaneObject.png)
- Assign the type of PixelPlane that you have and then click "Assign Type of PixelPlane."
- Note:As of version 12H, only type "Mega Tree" is currently supported.
- Complete the fields to help HLS understand your PixelPlane object, then click OK (See Figure 6-4).
![](/wiki/images/thumb/2/20/HLS_PixelPlane_ChannelManager.png/300px-HLS_PixelPlane_ChannelManager.png)
![](/wiki/images/thumb/d/d7/HLS_PixelPlane_DMXUniverse.png/300px-HLS_PixelPlane_DMXUniverse.png)
![](/wiki/images/thumb/b/b8/HLS_PixelPlane_AddDisplayGroup.png/300px-HLS_PixelPlane_AddDisplayGroup.png)
![](/wiki/images/thumb/4/40/HLS_PixelPlane_DisplayPixelPlane.png/300px-HLS_PixelPlane_DisplayPixelPlane.png)
Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: The PixelPlane | The PixelPlane Editor |
