HLS User Manual and Reference Guide - PDF 2013-02-06
Getting HLS
Download and Installation
Download HLS
- Tip: One way to organize the downloaded versions is to create a folder named "HLS Versions" and save downloads there.
- Unzip the HLS_Install_**.zip and four files will be created in a folder named the same as the zip file. These four files are:
- DBGHELP.DLL
- ftd2xx.dll
- HLS.exe
- ipworks8.dll
Folder Hierarchy
Note: Prior to version 16K, the HLS Program and Data all were contained within the HLS Application folder. Starting in version 16K, data can be set to any place you want. Your Documents folder, an external hard drive, etc. Follow the Moving HLS Data Directories page to separate data from application.
Wherever you decide to save HLS data, the following structure is suggested:
HLS HLS\Backgrounds HLS\Library HLS\Music
When you create an HLS sequence, HLS will create a folder under your HLS folder with the sequence name.
HLS Installation
- Now that you have the foundation of folders created, copy the four files from the HLS_Install_**.zip version into your "HLS" folder.
- Now you are ready to run HLS.
- Note: If you are using Windows 7 you need to change the properties of the HLS.exe file to run as Administrator.
- Open HLS.exe and begin to sequence.
OS Specific Installation
Upgrading HLS
Standard Upgrade
- Simply download the latest version, unzip the files, and overwrite the old files with the new ones.
Upgrade Path for Skipped Updates
- Upgrading from a version less than 11E: Install version 11H [2]
- Open any sequence you wish to keep in version 11H and Save Sequences.
- Upgrade from 11H to the most current version. [3]
- Open and Save sequences again to have them fully updated.
Creating a Sequence
Setting up the Sequence File:
![](/wiki/images/thumb/8/8d/HLS_MenuSelect_SequenceWizard.png/350px-HLS_MenuSelect_SequenceWizard.png)
![](/wiki/images/thumb/2/2a/HLS_SequenceWizard_MusicFilePrompt.png/350px-HLS_SequenceWizard_MusicFilePrompt.png)
![](/wiki/images/thumb/b/bd/HLS_SequenceWizard_FolderCreationPrompt.png/350px-HLS_SequenceWizard_FolderCreationPrompt.png)
![](/wiki/images/thumb/0/07/HLS_SequenceWizard_NameSequence.png/350px-HLS_SequenceWizard_NameSequence.png)
![](/wiki/images/thumb/f/f9/HLS_SequenceWizard_ReadyForAudio.png/350px-HLS_SequenceWizard_ReadyForAudio.png)
Setting up the Audio File:
![](/wiki/images/thumb/c/c8/Acquire-Wav-File-HLS.jpg/350px-Acquire-Wav-File-HLS.jpg)
![](/wiki/images/thumb/c/cf/HLS_SequenceWizard_AudioSelect.png/350px-HLS_SequenceWizard_AudioSelect.png)
![](/wiki/images/thumb/0/0f/Audio_file_confirmation.jpg/350px-Audio_file_confirmation.jpg)
![](/wiki/images/8/88/SaveComplete.jpg)
(12K)
(12K)
- 25 msec: This provides 40 timing grid spaces for every second.
- 50 msec: This provides 20 timing grid spaces for every second.
- 100 msec: This provides 10 timing grid spaces for every second.
- A higher grid resolution will result in more channels displayed on the screen at one time and more timing marks on display at one time, but the disadvantage is that the grid squares are smaller.
- A lower grid resolution will result in larger squares which are easier to see, but the disadvantage is fewer channels and timing marks on the screen at one time.
(12K)
