Renard 24HC
Renard 24HC
- The Renard 24HC Dimmer is the lastest edition of Frank Kostyun's 24 Channel All-In-One Christmas Lights Controller.
WLC Ventures now stocks the Renard 24HC here.
Previous comments about the schematic being identical to the Renard 64 is not correct.
RavingLunatic created the schematic below by tracing out the board. Note that this is NOT an official schematic, may have errors, and some reference designators are were derived for this schematic. This schematic is old and is being revised.
Media:Renard24 V33 Schematic package.pdf
Layout
Renard 24HC PCB
Assembly Instructions
For a full step by step document on how to build the Renard 24, please click the following link:
There have been changes made to both the board and the Bill of Materials that are inconsistent with the above document. The document is dated but is still a good resource for assembling the HC. Please note the following issues:
- The instructions call for two different Zener Diodes to be installed. Some kits are being supplied with two 1N5239B instead.
 - The current kit from WLC Ventures may use different numbers and types of terminals. For instance, where the BOM calls for 3 x 2 position terminals, the kit may contain 2 x 3 position terminals.
 - The part numbers printed on the PCB are outdated and many have been replaced. The schematic will be updated to match the BOM in the near future.
 - There is a 6 pin socket provided in the kit for the H1AA11 but if used, it creates an interference with the transformer. It can be assembled this way but removal of the H1AA11 will not be possible.
- Install Resistors R1 -> R24. These are 180 Ohm 1/4 Watt Resistors for 120VAC Operation.
 - Install Resistors R25 -> R53. These are 680 Ohm 1/4 Watt Resistors. R49 -> R53 are for the Diagnostic LEDs near the center of the PCB.
 - Install four 1kOhm Resistors. Two will be located above the transformer block and the other two are located below the RJ45 Jacks.
 - Install three 27kOhm Resistors. Two are located below the RJ45 Jacks and one just above the transformer
 - Install 120 Ohm Resistor below the RJ45 Jack
 - Install the 1N5239 Diode just below the RS485 chips
 - Install the 1N5229 Diode just below the RS485 chips. This may be substituted with a 1N5239 in some kits.
 - Install the 1N4001 Diode. This is located just above the transformer.
 - Install 24 Six Pin sockets. These are for the MOC3023 chips. Note the direction of the notch on the socket and ensure it matches the PCB. If you are planning on soldering the MOC3023 chips directly to the board, then skip this step.
 - Install one (1) Six Pin socket for the H1AA11. Note the direction of the notch on the socket and ensure it matches the PCB. If you are planning on soldering the H1AA11 chips directly to the board, then skip this step.
 - Install one (1) Six Pin socket for the Diode Bridge. Note the direction of the notch on the socket and ensure it matches the PCB. If you are planning on soldering the H1AA11 chips directly to the board, then skip this step. You will need to remove two of the pins from the socket to get this to fit. Simply push up on the two middle pins and pull them out from the top.
 - Install two (2) Eight Pin Sockets. Note the direction of the notch on the socket and ensure it matches the PCB. These are for the RS485 chips
 - Install three (3) Fourteen Pin Sockets for the Microprocessors. Note the direction of the notch on the socket and ensure it matches the PCB.
 - Install the oscillator. Note that one corner of the case is pointed...ensure this matches the silkscreen on the PCB.
 - Install five (5) 0.1 uF Capacitors. These are not polarized. If the leads do not match the holes, use a pair of needle nosed pliers to bend the leads to match. Do not pull or bend the lead right up to the body of the capacitor.
 - Install the five (5) indicator LEDs. The color of the LEDs may vary. The shorter leg of each LED goes into the SQUARE pad...WITH ONE EXCEPTION. The COMM FR pads are backwards and this LED must be installed with the LONG LEAD in the square pad.
 - Install the fuse clips. The clips may need to be bent back slightly to fit properly.
 - Install the Jumper Headers. These are four (4) sets of three pin headers. Alternatively, you can use a small jumper wire for the Transformer On/Off and the 120/240VAC selector.
 - Install channel output terminals. These are listed in the BOM as a single six pin terminal. However, these can be substituted with 2pin or 3 pin units that can be assembled together to create a six terminal block. Assemble these prior to installing by sliding them together (there is a small key/keyway on the side)
 - Install two (2) 10uF Electrolytic Capacitors. Note the STRIPE along the body of the capacitor. This is the NEGATIVE lead.
 - Install the four (4) angled terminals. Assemble these prior to installing by sliding them together (there is a small key/keyway on the side)
 - Install two (2) RJ45 Jacks along the top of the PCB
 - Install the voltage regulator. Note that the flat part of the regulator will face the RJ45 jacks at the top of the PCB.
 - Install twenty four (24) TRIACs. These are the chips that actually switch the AC current on and off. One trick to installing these is to attach them to the heat sink first, then install an entire side at one time.
 - Install the 1000 uF Electrolytic Capacitors. Note the STRIPE along the body of the capacitor. This is the NEGATIVE lead.
 - Install the Three Pin and Two Pin Power terminals. Assemble these prior to installing by sliding them together (there is a small key/keyway on the side)
 - Install the Heat Sink on the Voltage Regulator. This will take a bit of heat to get installed as the entire Heat Sink will need to heat up a bit.
 - Install the H1AA1 and the Diode Bridge if you have not already done so.
 - Install the Transformer. Note the location of Pin 1 of the transformer. There are numbers on the PCB and the Transformer itself.
Testing Points
The HC has 7 test points (TP1 to TP7)
TP1: GND
TP2: +5VDC
TP3: +12v
TP4: 12vac
TP5: 12vac
TP6: RS485A / RJ45 Pin 5
TP7: RS485B / RJ45 Pin 4
Design Notes for the HC PCB
The COMM FR LED pads are backwards - the cathode (short leg on the LED) will go into the round hole
Renard 24HC Jumper Settings and Options
Transformer On/Off: If on, the transformer recieves power from the left power input.
All Renard Firmware is located here: Renard_Firmware
Part Qty Description Renard 24HC PCB 1 Renard 24 Channel PCB 571-7969494 1 See note below for v3.3 595-SN75176BP 2 RS-485 Interface ICs Bus Diff 511-L7805CV 1 LM7805 Voltage Regulator 821-DB102G 1 Subsitute part 512-DF01M 532-7136DG 1 Heat Sink for 5V regulator 271-27K-RC 3 27k ohm 1/4 watt resistor 271-1K-RC 4 1k ohm 1/4 watt resistor 271-120-RC 1 120ohm 1/4 watt resistor 625-1N4001-E3 1 Standard Rectifiers Vr/50V Io/1A 78-1N5239B 2 Zener Diodes 9.1 Volt 0.5 Watt 838-3FD-320 1 Larger Transformer use part 838-3FD-420 782-H11AA1 1 Optocouplers Bi-Directional Input 520-TCF1843-X 1 Full Size Crystal Clock Oscillators DIP-14 5V 18.432MHz 140-HTRL25V1000-RC 1 Hi-Temp Radial Electrolytic Capacitors 25V 1000uF 105C 140-HTRL25V10-RC 1 Hi-Temp Radial Electrolytic Capacitors 25V 10uF 105C 534-3517 4 Fuse Clips and Holders PC FUSE CLIP 5 MM 504-GMA-15 2 5mm x 20mm Fast Acting Fuses 125VAC 15A Fast Acting 511-BTA04-700TRG 24 Triac Driver (24 needed) soon to be replaced by 511-BTA06-600 859-MOC3023 24 MOC 3023 Optocoupler 579-PIC16F688-I/P 3 Microchip PIC 16F1688''' 604-WP63ID 4 Red T1 3/4 LED, or any 10-30ma LED 604-WP1503GD 1 Green T1 3/4 LED or any 10-30ma LED 271-180-RC 24 180ohm 1/4 watt resistor 271-680-RC 29 680ohm 1/4 watt resistor 581-SA105E104MAR 5 .10 uF Ceramic Capacitor 571-9-146281-0 1 .100 three pin header(4 needed) Part specified is a 40 pin, cut off size that is needed. 571-2-382811-1 4 .100 Shunt (4 needed) You may also "steal" these off of old computer parts. 571-1-390261-2 2 8 pin DIP socket 571-1-390261-3 3 14 pin DIP socket 571-1-390261-1 26 Optional 6 Pin Socket for Optocoupler & H11AA1 571-5556416-1 2 RJ45 Sockets (2 needed) orientation doesn't matter. Specified part is same as the Ren64 571-2828376 6 6 Position Screw Down Terminal (Ren24 2.5 needs 4 of these) 158-P02EK508A3-E 4 3 Position Angled Screw Down Terminal 158-P02EHK508V3-E 1 3 Position Screw Down Terminal (power input) - higher current rating than prior part 158-P02EHK508V2-E 1 2 Position Screw Down Terminal (power input) - higher current rating than prior part
Hooking Up the Renard 24HC
Data Connections
Data Cables
- Data cables for Renard board connection directly to computer COMM port
- Data cable for Renard board connection using a RS232->RS485 converter or DMX Adapter
 RS485 Adapter Pinouts
    RS485(-) Signal to RJ45-pin 4
    RS485(+) Signal to RJ45-pin 5
- Data cable for Renard board connection to other Renard boards - Daisy Chain
- Generally only a regular straight-thru CAT5 cable is required to connect any Renard controller to another Renard controller. For the few exceptions (ie Ren24 V2.5), check the wiki page for those boards to see what their unique requirements are.
Cable Lengths
- The above image shows how Renard boards in general can be daisy chained together. Renard 64XC board is connected to the PC Serial Port. This board this then connected to a REN24HC, a REN SS24 and another REN64. The boards that are used in the image are just an example of how all Renard boards can be connected together. (The XMUS Ren16 and the REN24 v2.5 do have some issues...so read up on them first)
Computer Setup
- VIXEN Settings
- Protocol Version: 1
 - Parity: None
 - Data bits: 8
 - Stop bits: One
Errata for Rev HC PCB
1) COMM FR LED pads are backwards
