Electronics Hardware
Revision as of 02:05, 29 December 2007 by Fkostyun (talk | contribs)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS485, so a USB-RS485 (or RS232-RS485) converters are required. This system is available on a coop basis from time to time, with the kits including the boards, the parts, and pre-programmed microcontroller chips (PICs). This board is intermediate in complexity to build.
Renard
  • Documentation: Renard
Lynx
  • Controlled through: DMX
Ledtriks
JEC Pixel Displays
rgbLED
TBA
