Different Styles of Pixels
Pixels are RGB Light Emitting Diodes (LEDs) that allow a rainbow of individual colors to be created independently on each Pixel node. Pixels are Intelligent LEDs and have both power and control signals fed to each individual Pixel node. Using various communications protocols they are connected to Pixel Controllers that sends a specially formatted signal to the Pixel string that passes the control information to all of the Pixels connected in series. Each pixel uses 3 data channels to control it, one each for Red, Green and Blue.
Pixel Properties
Form Factor
- Strings - Can be any purchased in any custom length, but more then 50 pixels will require Power Injection. It important to remember that Pixel strings should never be strung using their wire to support them like you would with regular light stings. This will damage the Pixels and their waterproofing. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. Common methods to support Pixel strings include using cable ties or electric tape to attach them to PVC pipe, EMT electric conduit or Plastic Strapping. Strings are commonly used to make Megatrees, Minitrees and Leaping Arches.
- 12mm pixel - This is the most common Pixel type. They are often referred to as Bullet Shaped. It actually contains a 8mm LED inside the housing. The 12mm refers to the outer diameter of the package. These were orginally designed to mount inside of enclosures and are used for large advertising display screens.
- 12mm pixel (square) - These pixels can come with the wire coming either out of the back of the Pixel or the side of the Pixel. There has been some issues with the silicone injection molded units that have the wires coming out of the side not sealing and allowing water into the pixels.
- Pixels with Lens - There are a variety of Pixels available with Plastic Lens mounted on the RGB LED to make them look closer to a traditional C7 or C9 incandescent light. Common models include the Ge Color Effects (GECE), the Pixabulb by diyledexpress.com, the Cosmic Color Bulbs by Lightorama.com and the Technicolor Pixel by Ray Wu. Vendors like Ray Wu also sell Plastic lens that can be glued onto regular 12mm Pixel strings to achieve a similar look.
- Epoxy Resin Coating
- Solid Tube - The bare PCBs are also available in hollow tubes that have been filled with various waterproofing compoounds.
- Solid Silicone
- Solid Epoxy Resin
- Modules - Are very similar to strings, but are designed to be mounted to some surface and often have mounting tabs. They commonly have multiple RGB LEDs per pixels, so they are brighter then regular strings. Most are designed to run on 12VDC. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. They are frequently waterproofed by filling then with epoxy. They can come in metal or plastic housings. Modules are frequently used for lighting tune to signs, outline large objects and backlight Coro designs.
RGB LEDs per meter
LED Type
Waterproofing
- Injection Molded Silicone - These units have the wires coming out of the back or side and the biggest issue has been the failure of the silicone used to seal to the wires. Many early pixels had obvious areas where water could easily get into the Pixels. While many of the newer unts have better sealing, there is always the potential for the water to wick in along the wires if there is any stress on te wires due to wind pulling on the wires.
Wire Size
- LPD1101
- UCS6909
- UCS6912
- LPD8809
- SM16715
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
HolidayCoro.com
| String | WS2811 | 50 pixels (33ft) | 12vdc | 4 | 4 | link | $35.99 | $0.71 | IP68, Optional C9 lens, 8" spacing, 6ft leader cable, attached waterproof connectors |
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
Ray Wu
(China Based)
Waterproofing Pixels
Null Pixels
