Renard 24LV
Revision 1.0 Board (2008 Co-Op #1)
Layout
COOP PCB V1.0
Co-Op Board 3.0 Assembly Instructions
Currently in-process!
Design Notes for v 3.0 Co-Op Board
PCB 1 Ren24v3 Renard 24-Port PCB Board Specific Parts: 571-7969494 1 595-SN75176BP 2 511-L7805CV 1 821-DB102G 1 '''SUB PART 512-DF01M''' 532-7136DG 1 271-27K-RC 3 271-1K-RC 4 271-120-RC 1 625-1N4001-E3 1 78-1N5239B 2 838-3FD-320 1 782-H11AA1 1 520-TCF1843-X 1 140-HTRL25V1000-RC 1 140-HTRL25V10-RC 1 534-3517 4 504-GMA-15 2 Parts from the Common Parts List: (Common parts are the parts that are not unique to the Ren24, and may also be used in other designs) 579-PIC16F688-I/P 3 604-WP63ID 4 604-WP1503GD 1 271-180-RC 24 271-680-RC 5 581-SA105E104MAR 5 571-41032390 1 571-3828115 4 571-1-390261-2 2 571-1-390261-3 3 571-3902611 2 (Optional 6 Pin Socket for Optocoupler & H11A1 - Recommended) 571-5564161 6 Common Parts Description: ST Microelectronics BTA08 Triac Driver (24 needed) Microchip PIC 16F1688 (3 needed) Red T1 3/4 LED (4 needed) Green T1 3/4 LED (1 needed) 680ohm 1/4 watt resistor (5 needed) .1 uF Ceramic Capacitor (5 needed) .100 three pin header (7 needed) Part specified is a 40 pin, cut off size that is needed. Note - 1 header will give you enough to do 3 boards. .100 Shunt (7 needed) You may also "steal" these off of old computer parts. 6 pin DIP socket (optional - 25 needed) 8 pin DIP socket (2 needed) 14 pin DIP socket (3 needed) RJ45 Sockets (6 needed) orientation doesn't matter. Specified part is same as the Ren64
PC to Renard24 LV Cable
PC DB9 Pin 3 to RJ45-pin 4 PC DB9 Pin 5 to RJ45-pins 1,2,5 (pins 1 and 5 are required, pin 2 is optional).
Female DB9 connector as if you were looking into the end of it from the outside.
