Vastelec FM02
The FM02 is a two board FM transmitter. It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display. It comes just as shown in the picture shown above.
About VAST Electronics
Detailed Board Dimensions
Antenna
Most DIY'ers will want to convert this to the BNC type of connector because BNC components are easier to find. [[Image: FM02_sma_to_BNC_converter.jpg]]
Setup
They may also be available at WLC ventures.
They have also been seen for sale on ebay.
