Vastelec FM02
About VAST Electronics
Sure_electronics_voltage_regulator.jpg DO NOT apply anything GREATER then REGULATED 12V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit. These are about $5 online.
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
