Vastelec FM02
- Power. A regulated 12v DC power supply is needed. 100ma is enough current.
About VAST Electronics
DO NOT apply anything GREATER then REGULATED 9V-16V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit (Part number:PS-SP12113). These are about $5 online.
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Many folks will experience some HUM in the transmitted audio? This is normal. The good news is that you should be able to eliminate this hum with the use of a Ferrite Bead.
As far as size, you want to be able to wrap the wire through the hole and around the perimeter 3 times for maximum effect. You also need to wrap it tightly and secure it in place with a nylon tie wrap. So, it depends on the size of the wire that comes out of your wall wart, you need to have a diameter that can fit three wraps of the wire and the tie. Some Beads split in half, some don't !
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
