Renard PX1 Pixel Controller
General
Features
- Some Design Details:
The Renard PX1 can support up to a maximum of 200 pixels per controller. To achieve more then 200 pixels in a Renard system, multiple Renard PX1 pixel controllers must be used. The total number of pixels that may be supported per serial port depends on both the baud rate and on the frequency of updates that has been programmed into the Vixen sequence. The most common PC control software is Vixen, which easily supports multiple serial ports (including USB-RS232 and USB-485 converters).
Total Number of Pixels Capable for a given Baud Rate/Refresh Interval* | |||
Baud Rate | Refresh Interval | ||
100 ms | 50 ms | 25 ms | |
460800* | 1528 | 764 | 382 |
230400* | 764 | 382 | 191 |
115200 | 382 | 191 | 95 |
57600 | 191 | 95 | 47 |
38400 | 127 | 63 | 31 |
19200 | 63 | 31 | 15 |
Typical Pixels require power injection every 50 pixels. The Renard PX1 only supports up to 50 Pixels directly powered from the controller. If you use more then 50 Pixels (or if the cable is too long for the wire gauge), you must provide an off-board fused power source to provide power injection downstream.
PCB Layout
BOM - Bill Of Materials
Part | Mouser PN | Description | Qty |
R6 | 291-120-RC | Carbon Film Resistors - Through Hole 120ohms 0.05 | 1 |
R5,R7 | 299-1K-RC | Carbon Film Resistors - Through Hole 1Kohms 5% | 2 |
R1,R2 | 299-27K-RC | Carbon Film Resistors - Through Hole 27Kohms 0.05 | 2 |
R4 | 264-330-RC | Resistor Network, 330 Ohm, Bussed, 6-pin | 1 |
R3,R8 | 299-47-RC | Carbon Film Resistors - Through Hole 47ohms 0.05 | 2 |
C2,C3 | 810-FK28X5R1C105K | Multilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10% | 2 |
C1 | 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R | 1 |
D1 | 78-1N5239B | Diode, Zener 9.1V .5W | 1 |
D2 | 78-1N5229B | Diode, Zener 4.3V .5W | 1 |
D3,D4 | 604-WP710A10YT | LED, 3mm Yellow | 2 |
D5,D6 | 604-WP710A10GT | LED, 3mm Green | 2 |
IC1 | 595-SN65LBC179PE4 | Buffers & Line Drivers | 1 |
IC2 | 579-PIC16F1825-I/P | Microcontroller | 1 |
IC3 | 926-2950CZ-5.0/NOPB | LDO 5.0/100mA | 1 |
U1 | 571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 1 |
U2 | 571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 1 |
J5,J6 | 571-5556416-1 | Jack, Modular RJ45 PCB Mount Top Entry | 2 |
J4 | 538-22-03-2021 | Headers & Wire Housings VERT PCB HDR 2P TIN PLATING | 1 |
J3 | 649-77313-122-10LF | Headers & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH | 1 |
J2 | 538-22-03-2061 | Headers & Wire Housings VERT PCB HDR 6P TIN PLATING | 1 |
J1,J7 | 538-22-03-2031 | Headers & Wire Housings VERT PCB HDR 3P TIN PLATING | 2 |
J8 | 571-2828372 | Fixed Terminal Blocks 5.08MM PCB MOUNT 2P | 1 |
Jumpers | 151-8000-E | Headers & Wire Housings MINI JUMPER GF 6.0MM OPEN TYPE BLACK | 7 |
J9 | 538-39501-6004 | Pluggable Terminal Blocks 3.5MM EURO HEADER VE HEADER VERT GRN 4CKT | 1 |
Pixel Connector | 538-39503-2004 | Pluggable Terminal Blocks 3.50MM EURO PLUG VER UG VERT RWE BLK 4CKT | 1 |
Fuse | 504-ATM-5 | Fuses 5A 32Vdc 1kA IR Tan | 1 |
Fuse Holder | 534-3544-2 | Fuse Holder | 1 |
Assembly Instructions
- Configure Jumpers
- □ Install Resistors
- □ Install Capacitors
- □ Install Diodes
- □ Install IC Sockets
The notch faces right. - □ U2 - 14 pin socket. The socket has a notch on one end and the notch must be installed to match the direction on the silkscreen.
The Notch faces right.
- □ Install LEDs
- □ Install Voltage Regulator
- □ Install Fuse Holder
- □ Install Connectors
- □ Install RJ45 Jacks
- □ Install Fuse
- □ Install ICs
The IC has a notch on one end and the notch must be installed to match the direction on the silkscreen. - □ IC2 - PIC16F1825-I/P PIC microprocessor. The IC is polarized and it has to be installed with the correct orientation.
Configure Jumpers
Install a shunt (jumper) across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input. Otherwise, don't install any shunt here
J3- 2x5 Options Connector
J7- Voltage Selector
Program PIC
J2-ICSP Programming Header
J2 ICSP Pin Assignments | ||
Pin # | ||
Signal | ||
1 | VPP/MCLR | |
2 | VDD Target | |
3 | VSS (Ground) | |
4 | ICSPDAT/PGD | |
5 | ICSPCLK/PGC | |
6 | N/C |
Connections
Serial Data Connector Pin Assignments | ||
Pin # | RJ45 Connector | |
J5 Input | J6 Output | |
1,2 | GND | GND |
3 | NC | NC |
4 | Data- (Rx) | Data- (Tx) |
5 | Data+ (Rx) | Data+ (Tx) |
6,7,8 | NC | NC |
J8-Pixel Power Input
J8 Power Input | ||
Pin # | ||
Voltage | ||
1 (square pad on left) | GND (V-) | |
2 (round pad on right) | V+ |
J9 - Output to Pixels
J9 Pixel Output Pin Assignments | ||
Pin # | ||
Signal | ||
1 | GND (V-) | |
2 | Clock (C) | |
3 | Data (D) | |
4 | V+ |
Indicator LEDs
Attn
ON when J4 jumper for Renard Data Stream Configuration is in place.
Rx
FE
Pwr
- Baud Rate:
- Find the line in the code that says " #define BAUDRATE_INDEX_DEFAULT BAUDRATE_115200" and adjust the baudrate to one of the following values:
- RGB Order:
- Grouping:
- Choose your start address
- Example:
- If start address = 1
- Channel 1 = 0
- Channel 2 = 1
- If start address = 45
- Channel 1 = “0”
- Channel 2 = “45”
- If start address = 257
- Channel 1 = 1
- Channel 2 = 1
- Power off the PX1, install the jumper J4 on the PX1 then power ON the PX1 (the ATTN LED should be lit) and set up Vixen to send out the Renard data packets with the new address or configuration change.
PX1 Programming Packet Format
Inline PX1 Programming Settings | ||
Packet (Channel) | ||
Value | Default | |
1 | Start Address (MSB) | 0 |
2 | Start Address (LSB) | 1 |
3 | Baudrate Code | 4 |
4 | Group Size | 1 |
5 | Group Count | 50 |
6 | RGB Order Code | 0 |
Start Address Packet Format
Inline PX1 Programming Settings | ||||||
Start Address | Packet 1 MSB (Channel 1) |
Packet 2 LSB (Channel 2) | ||||
1-255 | 0 | Actual Start Address | ||||
256-511 | 1 | Start Address - 256 | ||||
512-767 | 2 | Start Address - 512 | ||||
768- 1023 | 3 | Start Address - 768 | ||||
1024-1279 | 4 | Start Address - 1024 |
Baud Rate Packet Format
Baud Rate | ||
Baud Rate Code Packet 3 (Channel 3) | ||
19200 | 0 | |
38400 | 1 | |
57600 | 2 | |
76800 | 3 | |
115200 | 4 (Default) | |
230400 | 5 | |
460800 | 6 |
Color Packet Format
Color Order | ||
RGB Code Packet 6 (Channel 6) | ||
RGB | 0 (Default) | |
RBG | 1 | |
GRB | 2 | |
GBR | 3 | |
BRG | 4 | |
BGR | 5 |
Enclosure
The PX1 has three screw holes that line up perfectly with the plastic standoffs in the inside of the TA-200 enclosure.
Initial Thread
Beta Test Thread
Group Buy Interest Thread
- Answer: Read The Pixel Newbie for step by step informations about setting up your first pixels.
Different Styles of Pixels
