Renard PX1 Pixel Controller
General
Features
- Some Design Details:
The Renard PX1 can support up to a maximum of 200 pixels per controller. To achieve more then 200 pixels in a Renard system, multiple Renard PX1 pixel controllers must be used. The total number of pixels that may be supported per serial port depends on both the baud rate and on the frequency of updates that has been programmed into the Vixen sequence. The most common PC control software is Vixen, which easily supports multiple serial ports (including USB-RS232 and USB-485 converters).
| 100 ms | 50 ms | 25 ms | |
| 230400* | 764 | 382 | 191 |
| 115200 | 382 | 191 | 95 |
| 57600 | 191 | 95 | 47 |
| 38400 | 127 | 63 | 31 |
| 19200 | 63 | 31 | 15 |
*A new Vixen plugin is required to support higher baudrates.
Typical Pixels require power injection every 50 pixels. The Renard PX1 only supports up to 50 Pixels directly powered from the controller. If you use more then 50 Pixels (or if the cable is too long for the wire gauge), you must provide an off-board fused power source to provide Power Injection downstream.
PCB Layout
BOM - Bill Of Materials
Assembly Instructions
- Configure Jumpers
- □ Install Resistors
- □ Install Capacitors
- □ Install Diodes
- □ Install IC Sockets
The notch faces right.
The Notch faces right.
- □ Install LEDs
- □ Install Voltage Regulator
- □ Install Fuse Holder
- □ Install Connectors
- □ Install RJ45 Jacks
- □ Install Fuse
- □ Install ICs
Configure Jumpers
Install a shunt (jumper) across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input.
J3- 2x5 Options Connector
J7- Voltage Selector
Program PIC
J2-ICSP Programming Header
| Pin # | ||
| Signal | ||
| 1 | VPP/MCLR | |
| 2 | VDD Target | |
| 3 | VSS (Ground) | |
| 4 | ICSPDAT/PGD | |
| 5 | ICSPCLK/PGC | |
| 6 | N/C | |
Connections
| Pin # | RJ45 Connector | |
| J5 Input | J6 Output | |
| 1,2 | GND | GND |
| 3 | NC | NC |
| 6,7,8 | NC | NC |
J8-Pixel Power Input
| J8 Power Input | ||
| Pin # | ||
| Voltage | ||
J9 - Output to Pixels
| Pin # | ||
| Signal | ||
| 1 | GND (V-) | |
| 2 | Clock (C) | |
| 3 | Data (D) | |
| 4 | V+ | |
Indicator LEDs
Attn
ON when J4 jumper for Renard Data Stream Configuration is in place.
Rx
FE
Pwr
- Baud Rate:
- Find the line in the code that says " #define BAUDRATE_INDEX_DEFAULT BAUDRATE_115200" and adjust the baudrate to one of the following values:
- RGB Order:
- Grouping:
- Choose your start address
- Example:
- If start address = 1
- Channel 1 = 0
- Channel 2 = 1
- If start address = 45
- Channel 1 = “0”
- Channel 2 = “45”
- If start address = 257
- Channel 1 = 1
- Channel 2 = 1
- Power off the PX1, install the jumper J4 on the PX1 then power ON the PX1 (the ATTN LED should be lit) and set up Vixen to send out the Renard data packets with the new address or configuration change.
PX1 Programming Packet Format
| Packet (Channel) | ||
| Value | Default | |
| 3 | Baudrate Code | 4 |
| 4 | Group Size | 1 |
| 5 | Group Count | 50 |
| 6 | RGB Order Code | 0 |
Start Address Packet Format
| Start Address | Packet 1 MSB (Channel 1) |
Packet 2 LSB (Channel 2) | ||||
Baud Rate Packet Format
| Baud Rate | ||
| Baud Rate Code Packet 3 (Channel 3) | ||
| 19200 | 0 | |
| 38400 | 1 | |
| 57600 | 2 | |
| 76800 | 3 | |
| 115200 | 4 (Default) | |
| 230400 | 5 | |
| 460800 | 6 | |
Color Packet Format
| Color Order | ||
| RGB Code Packet 6 (Channel 6) | ||
| RGB | 0 (Default) | |
| RBG | 1 | |
| GRB | 2 | |
| GBR | 3 | |
| BRG | 4 | |
| BGR | 5 | |
Enclosure
The PX1 has three screw holes that line up perfectly with the plastic standoffs in the inside of the TA-200 enclosure.
Initial Thread
Beta Test Thread
Group Buy Interest Thread
Different Styles of Pixels
Waterproofing Pixels
