PIX-C
Background
In the beginning the world smelled mostly of Nutmeg, and mulled cider. At that time Robert Jordan had an idea to create a DIY LED sign that could easily be made by the home Blinky Enthusiast. He called it LEDTRIKS and he showed it to the masses, and they thought it was good. In time however the world grew tired of Nutmeg and craved the spiceness of Gingerbread and TimW entered the scene. He designed a small controller that could offload the repetative task of refreshing the LED panel from the PC. He called it TRICKS-C and he showed it to the masses, and they thought it was good. While sitting looking at his LED panel Andrew Williams(no relation to TimW) theorized that he should be able to build a controller compatible with TRICKS-C, without the need to learn a new micro, purchase new tools, or install a new tool-chain. Entitled the PIX-C this controller will duplicate the functionality of the TRICKS-C, but use only parts already used on a typical RENARD controller. Now if only the world would smell like Candy Canes.
The Files
Bill of Materials
PIX-C v2.2 Mouser Quick Order BOM
PIX-C v2.4 Mouser Quick Order BOM
Note: Markings on the PCB SN75176BP are WRONG. The correct part is SN75179BP. This is listed correctly in the visual BOM above, and in the Mouser project.
Gerbers
ZIP Archive in the FILE LIBRARY
Main program ASM file File:Pix-c.asm.
Link to the entire ZIP archive. PIX-C ZIP Archive
Known Issues (PIX-C 2.2)
The serial re-transmit on the PIX-C 2.2 does not work properly. This results in corrupted image "downstream" of the first PIX-C. A simple hardware solution exists. Cut the trace coming FROM pin 6 of the PIC 16F688, and then jumper pins 2 & 3 of the SN75179BP. This will cause all incoming bits to be echoed as outgoing traffic. Version 2.4 of the PIX-C introduced a jumper that can be used to do this modification, rather than cutting traces on the board.
Build Instructions
Step 1 - Install 470 (R3,R8) ohm resistors
Step 2 - Install 1K (R1,R2,R4) ohm resistors
Step 3 - Install 1N5239B diode (NOTE: Orientation!)
Step 4 - Install 0.1 uf (C1,C3) capacitors
Step 5 - Install DIP sockets (NOTE: Notch/Pin 1 orientation)
Step 6 - Install LEDs (may not appear as shown)
Step 7 - Install RJ45 jacks (may not appear exactly as shown)
Step 8 - Install 10 uf (C2) capacitor (NOTE: Polarity !!)
Last Step - insert the RS485, and PIC chips into their sockets.
- NOTE: PIC should be programmed in advance. Do not attempt to use the "In Circuit Programming Header" as there is insufficient clearance to do so.
Controlling the PIX-C
The PIX-C is backwards compatible with the TRICKS-C and is thus controlled by the DOS LTC.exe program.
The following additional commands were added to LTC.exe version 11
#P_PROGRAM - used to program the panel addres into the PIX-C. #P_FSnXX - tell panel 'n' to display ROM image XX (0-7 ROM, 8&9 EPROM) #P_FWnXX - tell panel 'n' to store current image buffer at EEPROM location X (8/9)
Power connections
are shown in the following diagram.
