Quick Start Guide
Revision as of 13:58, 28 January 2013 by OriginalHotrodder (talk | contribs)
HLS Wiki Construction Notes
This section will eventually replace the HLS Getting Started Manual Colon and double braces
Installing HLS
Download HLS
  • Tip: One way to organize the downloaded versions is to create a folder named "HLS Versions" and save downloads there.
  • Unzip the HLS_Install_**.zip and four files will be created in a folder named the same as the zip file. These four files are:
DBGHELP.DLL
ftd2xx.dll
HLS.exe
ipworks8.dll
Folder Hierarchy
Note: Prior to version 16K, the HLS Program and Data all were contained within the HLS Application folder. Starting in version 16K, data can be set to any place you want. Your Documents folder, an external hard drive, etc. Follow the Moving HLS Data Directories page to separate data from application.
Wherever you decide to save HLS data, the following structure is suggested:
HLS
HLS\Backgrounds
HLS\Library
HLS\Music
When you create an HLS sequence, HLS will create a folder under your HLS folder with the sequence name.
HLS Installation
  • Now that you have the foundation of folders created, copy the four files from the HLS_Install_**.zip version into your "HLS" folder.
  • Now you are ready to run HLS.
  • Note: If you are using Windows 7 you need to change the properties of the HLS.exe file to run as Administrator.
  • Open HLS.exe and begin to sequence.
OS Specific Installation
Windows XP HLS Installation
Linux HLS Installation
OSX HLS Installation
1, 1.1, 1.2 1
2, 2.1, 2.2 2 Creating a Sequence
3, 3.1 3 Setting up Channels
3.4 4 Configuring Groups
Not yet existing 5 Copying Channel Effects
Added info 6 Adding or Deleting Channels
4.1 7 Creating a Preview
6.1 8 Adding a Beat Track
9, 9.1 - 9.4 9 Configuring the Sequence for Output
6.4 10 Creating Chases
6.5 Mirroring
6.8 12 Creating Custom Effects
6.9 13 Creating a library of Group Effects
7 14 Pixel Plane Effects
8, 8.1, 8.2 15 Play From a Mark 15.1 Changing the Play Speed
6.3 16 Apply an Over Control Ramp
9.3, 9.4 17 Creating a Playlist and a Schedule
6.3 18 Setting Defaults for Ramps, Level, and Minimum and Maximum Output Levels
5.1 19 Dimming Curves
7 20 RGB
Reference Guide 21 Converting 3 R, G, B channels Into a Single RGB Channel
Reference Guide 22 Converting Vixen Files to HLS
Reference Guide 23 Converting LOR Files to HLS
Not needed 24 Tutorial Video and Links
