Renard 24HC
Renard 24HC
- The Renard 24HC Dimmer is the lastest edition of Frank Kostyun's 24 Channel All-In-One Christmas Lights Controller.
WLC Ventures now stocks the Renard 24HC here.
Previous comments about the schematic being identical to the Renard 64 is not correct.
RavingLunatic created the schematic below by tracing out the board. Note that this is NOT an official schematic, may have errors, and some reference designators are were derived for this schematic. This schematic is old and is being revised.
Media:Renard24 V33 Schematic package.pdf
Layout
Renard 24HC PCB
Assembly Instructions
For a full step by step document on how to build the Renard 24, please click the following link:
Testing Points
The HC has 7 test points (TP1 to TP7)
TP1: GND
TP2: +5VDC
TP3: +12v
TP4: 12vac
TP5: 12vac
TP6: RS485A / RJ45 Pin 5
TP7: RS485B / RJ45 Pin 4
Design Notes for the HC PCB
The COMM FR LED pads are backwards - the cathode (short leg on the LED) will go into the round hole
Renard 24HC Jumper Settings and Options
Transformer On/Off: If on, the transformer recieves power from the left power input.
All Renard Firmware is located here: Renard_Firmware
Part Qty Description Renard 24HC PCB 1 Renard 24 Channel PCB 571-7969494 1 '''See note below for v3.3''' 595-SN75176BP 2 '''RS-485 Interface ICs Bus Diff''' 511-L7805CV 1 '''LM7805 Voltage Regulator''' 821-DB102G 1 '''subsitute part 512-DF01M''' 532-7136DG 1 '''Heat Sink for 5V regulator''' 271-27K-RC 3 '''27k ohm 1/4 watt resistor''' 271-1K-RC 4 '''1k ohm 1/4 watt resistor''' 271-120-RC 1 '''120ohm 1/4 watt resistor''' 625-1N4001-E3 1 '''Standard Rectifiers Vr/50V Io/1A''' 78-1N5239B 2 '''Zener Diodes 9.1 Volt 0.5 Watt''' 838-3FD-320 1 '''Larger Transformer use part 838-3FD-420''' 782-H11AA1 1 '''Optocouplers Bi-Directional Input''' 520-TCF1843-X 1 '''Full Size Crystal Clock Oscillators DIP-14 5V 18.432MHz''' 140-HTRL25V1000-RC 1 '''Hi-Temp Radial Electrolytic Capacitors 25V 1000uF 105C''' 140-HTRL25V10-RC 1 '''Hi-Temp Radial Electrolytic Capacitors 25V 10uF 105C''' 534-3517 4 '''Fuse Clips and Holders PC FUSE CLIP 5 MM''' 504-GMA-15 2 '''5mm x 20mm Fast Acting Fuses 125VAC 15A Fast Acting''' 511-BTA04-700TRG 24 '''Triac Driver (24 needed) soon to be replaced by 511-BTA06-600''' 859-MOC3023 24 '''MOC 3023 Optocoupler''' 579-PIC16F688-I/P 3 '''Microchip PIC 16F1688''' 604-WP63ID 4 '''Red T1 3/4 LED, or any 10-30ma LED''' 604-WP1503GD 1 '''Green T1 3/4 LED or any 10-30ma LED''' 271-180-RC 24 '''180ohm 1/4 watt resistor''' 271-680-RC 29 '''680ohm 1/4 watt resistor''' 581-SA105E104MAR 5 '''.10 uF Ceramic Capacitor''' 571-9-146281-0 1 '''.100 three pin header(4 needed) Part specified is a 40 pin, cut off size that is needed.''' 571-2-382811-1 4 '''.100 Shunt (4 needed) You may also "steal" these off of old computer parts.''' 571-1-390261-2 2 '''8 pin DIP socket''' 571-1-390261-3 3 '''14 pin DIP socket''' 571-1-390261-1 26 '''Optional 6 Pin Socket for Optocoupler & H11AA1''' 571-5556416-1 2 '''RJ45 Sockets (2 needed) orientation doesn't matter. Specified part is same as the Ren64''' 571-2828376 6 '''6 Position Screw Down Terminal (Ren24 2.5 needs 4 of these)''' 158-P02EK508A3-E 4 '''3 Position Angled Screw Down Terminal''' 158-P02EHK508V3-E 1 '''3 Position Screw Down Terminal (power input) - higher current rating than prior part''' 158-P02EHK508V2-E 1 '''2 Position Screw Down Terminal (power input) - higher current rating than prior part'''
Hooking Up the Renard 24HC
Data Connections
Data Cables
- Data cables for Renard board connection directly to computer COMM port
- Data cable for Renard board connection using a RS232->RS485 converter or DMX Adapter
 RS485 Adapter Pinouts
    RS485(-) Signal to RJ45-pin 4
    RS485(+) Signal to RJ45-pin 5
- Data cable for Renard board connection to other Renard boards - Daisy Chain
- Generally only a regular straight-thru CAT5 cable is required to connect any Renard controller to another Renard controller. For the few exceptions (ie Ren24 V2.5), check the wiki page for those boards to see what their unique requirements are.
Cable Lengths
- The above image shows how Renard boards in general can be daisy chained together. Renard 64XC board is connected to the PC Serial Port. This board this then connected to a REN24HC, a REN SS24 and another REN64. The boards that are used in the image are just an example of how all Renard boards can be connected together. (The XMUS Ren16 and the REN24 v2.5 do have some issues...so read up on them first)
Computer Setup
- VIXEN Settings
- Protocol Version: 1
 - Parity: None
 - Data bits: 8
 - Stop bits: One
Errata for Rev HC PCB
1) COMM FR LED pads are backwards
