Search results
- ...connector pin 18 thru pin 25 (at least one of these pins must be a direct short to U1 IC socket pin 1) ::#:#:*If any of the above readings are not a direct short, then check the data cable wiring as compared to the [[The_GRINCH_Controlle ...5 KB (832 words) - 04:46, 29 January 2011
- ...ign=center|2||align=center|604-wp7104gt||align=center|Ch2Diag #1 & #2||The short leg of the led goes to the flat side of the silkscreening ...has a '''N''' and and a '''NC''' marked on the silkscreen overlay. using a short piece of jumper wire, solder a connection between the '''NC''' on the termi ...10 KB (1,694 words) - 17:11, 26 July 2013
- ...distance from the converter to the Grinch/595 controller should be kept as short as possible. I use a 1 foot cable with mine and mount it in the same enclo ...5 KB (859 words) - 04:50, 29 January 2011
- ...e input cable can be a 9-pin straight-through cable. It should be kept as short as possible, on the order of 20 feet or less. A shunt should be installed b ...left open, perhaps covered with a wire nut to protect it from inadvertant short-circuits. ...14 KB (2,010 words) - 03:56, 29 January 2011
- ...604-WP7104GT). The LEDs are polarized and must be mounted correctly. The short lead is the cathode and must be placed in the square solder pad. Another w ...10 KB (1,648 words) - 03:08, 29 January 2011
- ...4-WP710A10GT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...4-WP710A10IT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...17 KB (2,807 words) - 14:09, 5 August 2013
- ...4-WP710A10GT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...4-WP710A10IT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...17 KB (2,764 words) - 22:56, 28 December 2020
- ...4-WP710A10GT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...4-WP710A10IT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...17 KB (2,779 words) - 22:55, 28 December 2020
- ...4-WP710A10GT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...4-WP710A10IT). The LEDs are polarized and must be installed correctly. The short lead is the cathode and must be placed in the square solder pad. ...17 KB (2,789 words) - 22:56, 28 December 2020
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...layout is in the power cables. Most of the channel power cables are very short. This system is very good for widely spaced display items with small group ...16 KB (2,463 words) - 02:19, 11 July 2013
- ...current flow. When checking for continuity you are usually looking for a short. ;Jumper : A short length of wire used to complete a circuit. ...29 KB (4,656 words) - 20:42, 29 April 2015
- ...e only getting 5 - 0.3834 = 4.6166V a drop of only 8%! That may work for short strings of pixels. ...ting 5V they are only getting 5 - 0.1917 = 4.8083V a drop of only 4%! '''Short thick wires are the answer!''' ...25 KB (3,989 words) - 03:06, 31 December 2015
- ::#:*Probably there is a short on the pcb or a bad solder joint, go to [[#Other Troubleshooting | Other Tr ...24 KB (3,857 words) - 04:47, 29 January 2011
- ...s layout is in the power cables. Most of the channel power cables are very short. This system is very good for widely spaced display items with small groups ...p.short], [http://doityourselfchristmas.com/forums/member.php?583-scorpia p.rogers]. ...24 KB (4,144 words) - 21:36, 31 May 2013
- ...able of switching 5-24VDC at up to maximum of 500ma per channel for a very short period of time you should not exceed 400ma per channel for continuous use. ...p.short], [http://doityourselfchristmas.com/forums/member.php?583-scorpia p.rogers] and [http://doityourselfchristmas.com/forums/member.php?1986-budude ...26 KB (4,651 words) - 08:42, 17 February 2014
- ...h] and [http://doityourselfchristmas.com/forums/member.php?9-P.-Short Phil Short]. They are available from [http://www.diyledexpress.com/index.php?main_page ...You need to solder eight jumpers through these holes to each of the PCBs. Short lengths or wire or cutoff leads from resistors or other components work gre ...23 KB (3,897 words) - 14:19, 3 August 2013
- ...f controllers so much of the credit goes to Wayne James and of course Phil Short for their contributions. The output section is taken from the Ren48LSD but Configure a short Vixen sequence with a slow on/off sequence for each channel - 1 second on, ...26 KB (4,577 words) - 02:58, 2 June 2015
- ...gned by [http://doityourselfchristmas.com/forums/member.php?9-P-Short Phil Short] as an inexpensive Pixel controller designed to work with standard Renard s #<span style="font-size:21px">□</span> Install Headers. '''The short end of the header is soldered into the PCB.''' ...39 KB (6,334 words) - 15:14, 23 February 2022
- #Install the headers. The short end of the header is soldered into the PCB. ...You need to solder eight jumpers through these holes to each of the PCBs. Short lengths or wire or cutoff leads from resistors or other components work gre ...21 KB (3,673 words) - 21:12, 28 June 2013
- The COMM FR LED pads are backwards - the cathode (short leg on the LED) will go into the round hole ...12 KB (1,791 words) - 17:09, 26 July 2013
