Figured since I was sitting around, waiting, I'd build some of the "fake" SSR's for testing. Had to dig pretty hard to find the info, so figured I'd post it again, here, in case you need it.
From David:
I also made myself a set of “fake” SSRs for one field module just for testing. You take a short piece of cable and four resistors (820 ohm). Connect each resistor to a channel (Orange, Blue, Green, Brown) and connect the other ends of the resistors to 5VDC (Orange/White) for sinking applications. A bit of electrical tape to insulate the resistors and crimp a RJ-45 plug on the other end. Make 8 of them and this will allow the addressing to work and will light up the LEDs for testing.
I've also made up some quick boards, for anyone that wants some. They'll come in a sheet of 8, if you have a way of cutting them apart. If you need them cut apart, I'll do that, as well. They will come drilled. You need 8 RJ45 Jacks, and 64 810 Ω resistors. You'll also need a short cat5 cable, or, you can hard-wire a short piece to the board, using the RJ45 jack holes.
Let me know if you would like a set. I can do a set of 8 6" Cat5 cables as well, but would have to charge a little bit for shipping, and don't want to step on any toes, calling it a "group buy" or anything like that. If you'd like a set of cables, PM me, and we'll go from there. I like etching, and I buy my Cat5 ends by the 1000, more than I'll EVER use in my lifetime! Pay it forward, I always say...
EDIT: Someone asked about shipping - no charge for a board of 8 (or 8 cut apart), if you want the cables, I would send them in a $4.95 flat rate box. The nice thing about not cutting the board, is you can just plug 8 cables into one board...
R
