HI everyone. I've been also having troubles while converting my vix sequences to use them with the new version of vixen. I've done all what you've say before, but I can't solve the problem. I'm running vixen in windows xp, and have upgraded to the lastest version of it. When I run the program, the prepare thing happens, (it does't say any clue of what sequences has converted) but says it has finished. When I try to open a sequence, it apears an error message, which details are the following:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Vixen.EventSequence.LoadFromXml(XmlNode contextNode)
at Vixen.EventSequence..ctor(String fileName)
at StandardSequence.StandardSequence.Open(String filePath)
at Vixen.Form1.OpenSequence(String fileName)
at Vixen.Form1.openALightingProgramToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Vixen
Assembly Version: 2.1.1.0
Win32 Version: 2.1.1.0
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Vixen.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
fmod
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/fmod.DLL
AnalogSpectrum
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/AnalogSpectrum.DLL
CometConversion
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/CometConversion.DLL
DMXAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/DMXAddIn.DLL
MIDIReader
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/MIDIReader.DLL
Prop1SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Prop1SeqGen.DLL
Prop2SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Prop2SeqGen.DLL
RemoteClient
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/RemoteClient.DLL
RGBLEDAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/RGBLEDAddIn.DLL
Spectrum
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Spectrum.DLL
WattMeter
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/WattMeter.DLL
Waveform
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Waveform.DLL
LedTriksUI
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/LedTriksUI.DLL
LedTriksUtil
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/Output/LedTriksUtil.DLL
StandardScript
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/StandardScript.DLL
ScriptEngine
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/ScriptEngine.DLL
StandardSequence
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/StandardSequence.DLL
TriggerResponse
CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/TriggerResponse.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Any ideas of what could it be?
Thanks since now.
Nicolas
