Esp Code for various modules
angus40
Supporting Member
Thought I would start a thread for sharing working sketches .
This is for esp8266 wemos . Uses FastLed & older E131
May also work on Esp-01, not tested
Code:
  E131_Test.ino - Simple sketch to listen for E1.31
  Project: E131 ESP8266 and FastLed
  Copyright (c)  Shelby Merrick
  http://www.forkineye.com
   This program is provided free for you to use in any way that you wish,
   subject to the laws and regulations where you are using it.  Due diligence
   is strongly suggested before using this code.  Please give credit where due.
   The Author makes no warranty of any kind, express or implied, with regard
   to this program or the documentation contained in this document.  The
   Author shall not be liable in any event for incidental or consequential
   damages in connection with, or arising out of, the furnishing, performance
   or use of these programs.
#include <ESP8266WiFi.h>
#include <E131.h>
#include <FastLED.h>
#define UNIVERSE 1                      // First DMX Universe to listen for
#define CHANNEL_START 1
#define DATA_PIN 2
#define NUM_LEDS 170
CRGB newLeds[NUM_LEDS];
const char ssid[] = "SSID";         // Replace with your SSID
const char passphrase[] = "PASSWORD";   // Replace with your WPA2 passphrase
// ESPAsyncE131 instance with UNIVERSE_COUNT buffer slots
E131 e131;
void setup() {
  Serial.begin(115200);
  delay(10);
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(newLeds, NUM_LEDS);
  // Make sure you're in station mode
  WiFi.mode(WIFI_STA);
  Serial.println("");
  Serial.print(F("Connecting to "));
  Serial.print(ssid);
  if (passphrase != NULL)
    WiFi.begin(ssid, passphrase);
  else
    WiFi.begin(ssid);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print(F("Connected with IP: "));
  Serial.println(WiFi.localIP());
  // Choose one to begin listening for E1.31 data
  //if (e131.begin(E131_UNICAST))                               // Listen via Unicast
  //if (e131.begin(E131_MULTICAST, UNIVERSE, UNIVERSE_COUNT))   // Listen via Multicast
  e131.beginMulticast(ssid, passphrase, UNIVERSE);
  Serial.println(F("Listening for data..."));
void loop() {
  if (e131.parsePacket()) {
    if (e131.universe == 1) {
      for (int i = 0; i < NUM_LEDS; i++) {
        int j = i * 3 + (CHANNEL_START - 1);
        newLeds[i] = (i, (CRGB(e131.data[j], e131.data[j + 1], e131.data[j + 2])));
      FastLED.show();
Esp8266 Wemos, EspAsyncE131 , FastLed
May also work on esp-01 , not tested .
Code:
  Project: ESPAsyncE131  ESP8266 and FastLed
  Copyright (c) 2019 Shelby Merrick
#include <ESPAsyncE131.h>
#define UNIVERSE_COUNT 2
#define DATA_PIN 2
ESPAsyncE131 e131(UNIVERSE_COUNT);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  else
    Serial.println(F("*** e131.begin failed ***"));
void loop() {
  if (!e131.isEmpty()) {
    e131_packet_t packet;
    e131.pull(&packet);     // Pull packet from ring buffer
    uint16_t universe = htons(packet.universe);
    if (universe == 1) {
      if (packet.property_values[(CHANNEL_START - 1)] < NUM_LEDS) {
        for (int n = 0; n < NUM_LEDS; n++) {
          int j = n * 3 + (CHANNEL_START);
          newLeds[n] = (n, (CRGB(packet.property_values[j] , packet.property_values[j + 1], packet.property_values[j + 2])));
          //Serial.println(packet.property_values[j]);
        FastLED.show();
        /*   Serial.printf("Universe %u / %u Channels | Packet#: %u / Errors: %u / CH1: %u\n",
                   htons(packet.universe),                 // The Universe for this packet
                   htons(packet.property_value_count) - 1, // Start code is ignored, we're interested in dimmer data
                   e131.stats.num_packets,                 // Packet counter
                   e131.stats.packet_errors,               // Packet error counter
                   packet.property_values[1]);             // Dimmer data for Channel 1     */
Esp8266 Wemos, EspAsyncE131, NeoPixelBus
May work on Esp-01 , not tested
Code:
  E131_Test.ino - Simple sketch to listen for E1.31 data on an ESP32
                   and print some statistics.
  Project: ESPAsyncE131 - Asynchronous E.131 (sACN) library for Arduino ESP8266
#include <NeoPixelBus.h>
#define UNIVERSE_COUNT 2          // Total number of Universes to listen for, starting at UNIVERSE
const uint16_t PixelCount = 170; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin = 2;  // make sure to set this to the correct pin, ignored for Esp8266
NeoPixelBus<NeoGrbFeature, NeoEsp8266BitBangWs2812xMethod> strip(PixelCount, PixelPin);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
 /* Initialize output */
    pinMode(PixelPin, OUTPUT);
    digitalWrite(PixelPin, LOW);
 // this resets all the neopixels to an off state
    strip.Begin();
    strip.Show();
  if (e131.begin(E131_MULTICAST, UNIVERSE, UNIVERSE_COUNT));   // Listen via Multicast
void loop() {
     if (packet.property_values[(CHANNEL_START - 1)] < PixelCount) {
      for (int i = 0; i < PixelCount; i++) {
            int j = i * 3 + (CHANNEL_START );
              strip.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j+1], packet.property_values[j+2])));
            Serial.println(packet.property_values[j] );;
            strip.Show();
ESP32 ,EspAsyncE131 & NeoPixelBus (This provides 2 functional GPIO * 2 Universes as configured , with the possibly of more through experimentation )
Code:
  All credits to :
  Shelby Merrick for his E131
  Michael Miller for the NeoPixel_Bus
  Project: ESPAsyncE131 - Asynchronous E.131 (sACN) library for Arduino ESP8266 and ESP32
  NeoPixelBus Test
  https://github.com/Makuna/NeoPixelBus/wiki/ESP8266-NeoMethods
#include <WiFi.h>
#define CHANNEL_START_A 1
#define UNIVERSE_COUNT 3
#define CHANNEL_START_B 1
const uint16_t PixelCount1 = 81; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin1 = 12;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount2 = 81; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin2 = 15;  // make sure to set this to the correct pin, ignored for Esp8266
ESPAsyncE131 e131(3);
NeoPixelBus<NeoGrbFeature, NeoEsp32I2s0Ws2812xMethod> strip1(PixelCount1, PixelPin1);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt0800KbpsMethod> strip2(PixelCount2, PixelPin2);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  strip1.Begin();
  strip1.Show();
  strip2.Begin();
  strip2.Show();
void loop() {
  while (!e131.isEmpty()) {
      //if (packet.property_values[(CHANNEL_START_A - 1)] < PixelCount1) {
        for (int i = 0; i < PixelCount1; i++) {
          int j = i * 3 + (CHANNEL_START_A );
          strip1.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
        strip1.Show();
    if ((universe == 2) && (packet.property_values[(CHANNEL_START_B - 1)] == (packet.property_values[0]))) {   << Change the (packet.property_values "0 ") to suit your pixel count >>
        for (int i = 0; i < PixelCount2; i++) {
          int j = i * 3 + (CHANNEL_START_B );
          strip2.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
          Serial.println(packet.property_values[j + 1] );
        strip2.Show();
i could not find any code online for the Esp32 :(
Thanks to Michael Miller and his NeoPixelBus I was able to see some blinky .
It would be awesome to see the TLS made to work with these modules : :wink::wink:
Esp32, NeoPixelBus, I2s, & 2 GPIO
This is the one of the best configurations that has worked so far !
One hurdle I have overcome with figuring out the coding is that there is a huge difference between universe & UNIVERSE . :)
Code:
  All credits to :
  NeoPixelTest
#include <WiFi.h>
const uint16_t PixelCount1 = 170; // this example assumes 4 pixels, making it smaller will cause a failure
const uint16_t PixelCount2 = 170; // this example assumes 4 pixels, making it smaller will cause a failure
//NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt0800KbpsMethod> strip1(PixelCount1, PixelPin1);
//NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt1800KbpsMethod> strip2(PixelCount2, PixelPin2);
//NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt2800KbpsMethod> strip3(PixelCount3, PixelPin3);
//NeoPixelBus<NeoGrbFeature, NeoEsp32BitBangWs2813Method> strip3(PixelCount3, PixelPin3);
NeoPixelBus<NeoGrbFeature, NeoEsp32I2s1800KbpsMethod> strip1(PixelCount1, PixelPin1);
NeoPixelBus<NeoGrbFeature, NeoEsp32I2s0800KbpsMethod> strip2(PixelCount2, PixelPin2);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  strip1.Begin();
  strip1.Show();
  strip2.Begin();
  strip2.Show();
  //if (e131.begin(E131_UNICAST));                              // Listen via Unicast
void loop() {
        //Serial.println(packet.property_values[j] );
      //strip1.Dirty();
      strip1.Show();
      //if (packet.property_values[(CHANNEL_START_B - 1)] < PixelCount2) {
        //Serial.println(packet.property_values[j + 1] );
      //strip2.Dirty();
      strip2.Show();
Esp32, Esp8266 , EspAsyncE131 , FastLed 2* GPIO Unicast
Also works with the old E131 version for esp8266
Code:
//#include <ESP8266WiFi.h> // Uncomment for esp8666 & comment out WiFi.h
#include <WiFi.h>           // Uncomment for esp32 & comment out ESP8266WiFi.h
#define NUM_LEDS_PER_STRIP_B 81
#define NUM_LEDS_PER_STRIP_A 81
#define UNIVERSE  1
#define DATA_PIN 15
CRGB newLeds[NUM_LEDS_PER_STRIP_B];
CRGB oldLeds[NUM_LEDS_PER_STRIP_A];
ESPAsyncE131 e131(10);
void setup() {
  delay(10);
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(newLeds, NUM_LEDS_PER_STRIP_B);
  FastLED.addLeds<NEOPIXEL, 5>(oldLeds, NUM_LEDS_PER_STRIP_A);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  //e131.beginMulticast(ssid, passphrase,  );
void loop() {
        for (int i = 0; i < NUM_LEDS_PER_STRIP_B; i++) {
           newLeds[i] = (i, (CRGB(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
        FastLED.show();
    if ((universe == 2) && (packet.property_values[(CHANNEL_START_B - 1)] == (packet.property_values[245]))) {
           for (int i = 0; i < NUM_LEDS_PER_STRIP_A; i++) {
          oldLeds[i] = (i, (CRGB(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
        FastLED.show();
*************SOLVED ***********
6 GPIO on the Esp32 dev board is all I can do for pixel output .
more learning to do :)
Esp32 12 Universe successfully working !!! Could probably add 5 more .
BitBang is not 100% or as lossless as RMT .
Next challenge to turn the Esp32 into a dumb rgb controller .
Code:
  All credits to :
  NeoPixelTest
#include <WiFi.h>
#define UNIVERSE_COUNT 12
#define CHANNEL_START_C 1
#define CHANNEL_START_D 1
#define CHANNEL_START_E 1
#define CHANNEL_START_F 1
#define CHANNEL_START_G 1
#define CHANNEL_START_H 1
#define CHANNEL_START_I 1
#define CHANNEL_START_J 1
#define CHANNEL_START_K 1
#define CHANNEL_START_L 1
const uint16_t PixelCount1 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin1 = 23;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount2 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin2 = 22;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount3 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin3 = 21;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount4 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin4 = 19;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount5 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin5 = 18;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount6 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin6 = 17;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount7 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin7 = 4;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount8 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin8 = 15;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount9 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin9 = 0;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount10 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin10 = 16;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount11 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin11 = 27;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount12 = 6; // this example assumes 4 pixels, making it smaller will cause a failure
const uint8_t PixelPin12 = 25;  // make sure to set this to the correct pin, ignored for Esp8266
ESPAsyncE131 e131(12);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt3800KbpsMethod> strip4(PixelCount4, PixelPin4);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt4800KbpsMethod> strip5(PixelCount5, PixelPin5);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt5800KbpsMethod> strip6(PixelCount6, PixelPin6);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt6800KbpsMethod> strip7(PixelCount7, PixelPin7);
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt7800KbpsMethod> strip8(PixelCount8, PixelPin8);
NeoPixelBus<NeoGrbFeature, NeoEsp32BitBang800KbpsMethod> strip9(PixelCount9, PixelPin9);
NeoPixelBus<NeoGrbFeature, NeoEsp32BitBang800KbpsMethod> strip10(PixelCount10, PixelPin10);
NeoPixelBus<NeoGrbFeature, NeoEsp32BitBang800KbpsMethod> strip11(PixelCount11, PixelPin11);
NeoPixelBus<NeoGrbFeature, NeoEsp32BitBang800KbpsMethod> strip12(PixelCount12, PixelPin12);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  strip1.Begin();
  strip1.Show();
  strip2.Begin();
  strip2.Show();
  strip3.Begin();
  strip3.Show();
  strip4.Begin();
  strip4.Show();
  strip5.Begin();
  strip5.Show();
  strip6.Begin();
  strip6.Show();
  strip7.Begin();
  strip7.Show();
  strip8.Begin();
  strip8.Show();
  strip9.Begin();
  strip9.Show();
  strip10.Begin();
  strip10.Show();
  strip11.Begin();
  strip11.Show();
  strip12.Begin();
  strip12.Show();
void loop() {
  // Parse a packet and update pixels
        int j = i * 3 + (CHANNEL_START);
      strip1.Show();
    if (universe == 2) {
        int j = i * 3 + (CHANNEL_START_B);
      strip2.Show();
    if (universe == 3) {
      for (int i = 0; i < PixelCount3; i++) {
        int j = i * 3 + (CHANNEL_START_C);
        strip3.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip3.Show();
    if (universe == 4) {
      for (int i = 0; i < PixelCount4; i++) {
        int j = i * 3 + (CHANNEL_START_D);
        strip4.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip4.Show();
    if (universe == 5) {
      for (int i = 0; i < PixelCount5; i++) {
        int j = i * 3 + (CHANNEL_START_E);
        strip5.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip5.Show();
    if (universe == 6) {
      for (int i = 0; i < PixelCount6; i++) {
        int j = i * 3 + (CHANNEL_START_F);
        strip6.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip6.Show();
    if (universe == 7) {
      for (int i = 0; i < PixelCount7; i++) {
        int j = i * 3 + (CHANNEL_START_G);
        strip7.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip7.Show();
    if (universe == 8) {
      for (int i = 0; i < PixelCount8; i++) {
        int j = i * 3 + (CHANNEL_START_H);
        strip8.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip8.Show();
    if (universe == 9) {
      for (int i = 0; i < PixelCount9; i++) {
        int j = i * 3 + (CHANNEL_START_I);
        strip9.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip9.Show();
    if (universe == 10) {
      for (int i = 0; i < PixelCount10; i++) {
        int j = i * 3 + (CHANNEL_START_J);
        strip10.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip10.Show();
     if (universe == 11) {
      for (int i = 0; i < PixelCount11; i++) {
        int j = i * 3 + (CHANNEL_START_K);
        strip11.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip11.Show();
     if (universe == 12) {
      for (int i = 0; i < PixelCount12; i++) {
        int j = i * 3 + (CHANNEL_START_L);
        strip12.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
      strip12.Show();
Pixels , rgb channels easily controlled at the same time with multi Universe configuration .
Thoroughly tested using Unicast and works excellently.
Note: I found it wise to add a 10k resistor from gate to gnd on each of the N-channel mosfets .
Example sketch enjoy !
Code:
  All credits to :
  NeoPixelTest
#include <WiFi.h>
#define RPIN 15   //R pin for analog LED strip
#define GPIN 13   //G pin for analog LED strip
#define BPIN 12   //B pin for analog LED strip
const uint8_t PixelPin1 = 27;  // make sure to set this to the correct pin, ignored for Esp8266
const uint16_t PixelCount2 = 6; // Should be set to no less than 4 for R,G,B channels
const uint8_t PixelPin2 = 15;  //Use a r,g,b Pin to satisfy the NeoPixelBus Instance
const char ssid[] = "";         // Replace with your SSID
const char passphrase[] = "!";   // Replace with your WPA2 passphrase
NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt1800KbpsInvertedMethod> strip2(PixelCount2, PixelPin2);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
  ledcSetup(0, 5000, 8);
  ledcAttachPin(RPIN, 0);
  ledcSetup(1, 5000, 8);
  ledcAttachPin(GPIN, 1);
  ledcSetup(2, 5000, 8);
  ledcAttachPin(BPIN, 2);
  strip1.Begin();
  strip1.Show();
void loop() {
  int val;
  int val1;
  int val2;
    uint8_t *data = packet.property_values + 1;
      strip1.Show();
         /* channel selection ; if not in sequential order you may get lag*/
      val = map((packet.property_values[(CHANNEL_START_A)]), 0, 255, 0, 255);   // You change the channels here
      val1 = map((packet.property_values[(CHANNEL_START_A  + 1)]), 0, 255, 0, 255);
      val2 = map((packet.property_values[(CHANNEL_START_A  + 2)]), 0, 255, 0, 255);
      if (val <= 255 || val > 1) {
        ledcWrite(0, val);  //RPIN;
      if (val1 <= 255 || val1 > 1) {
        ledcWrite(1, val1);  //GPIN
      if (val2 <= 255 || val2 > 1) {
        ledcWrite(2, val2); //BPIN
E131 WS 2801 FastLed Esp8266 Nodemcu
This will work on Wemos too !
Code:
#include "FastLED.h"
#include <E131.h>
#define NUM_LEDS   6
#define DATA_PIN     2
#define CLOCK_PIN   3
const char ssid[] = "0000000000";         /* Replace with your SSID */
const char passphrase[] = "00000000000";   /* Replace with your WPA2 passphrase */
CRGB leds[NUM_LEDS];
E131 e131;
void setup() {
  while (!Serial); // wait for serial attach
  Serial.println();
  Serial.println("Initializing...");
  Serial.flush();
  /* Choose one to begin listening for E1.31 data */
  //e131.begin(ssid, passphrase);                       /* via Unicast on the default port */
  e131.beginMulticast(ssid, passphrase, UNIVERSE);  /* via Multicast for Universe 1 */
     FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
void loop() {
  /* Parse a packet and update pixels */
    if (e131.universe == UNIVERSE, 1) {
        int j = i * 3 + (CHANNEL_START -1 );
        leds[i] = (i, (CRGB(e131.data[j], e131.data[j + 1], e131.data[j + 2])));
      FastLED.show();
Esp8266 hwSPI ... test and works very clean and fast .
Ws 2801 pixels used .
Thanks to <> Copyright (c) 2015 David Ogilvy (MetalPhreak)
You can source -> https://github.com/MetalPhreak/ESP8266_SPI_Driver
Code:
#include "spi.c"                  <<<<<<
#include "driver/spi.h"        <<<<<<   (these are required to be in the .ino folder )
#include "spi_register.h"     <<<<<<    ( for copy & paste to work )
int RED[4];
int GREEN[4];
int BLUE[4];
//setup code
void setup()
  spi_init(HSPI);
  spi_tx8(HSPI, 0x7A); //send 8 bits of data
  spi_tx16(HSPI, 0x7A43); //send 16 bits of data
  spi_tx32(HSPI, 0xCAFEFEED); //send 32 bits of data
  spi_txd(HSPI, 9, 0b101101110); //send 9 bits of data (useful for driving LCDs with 9bit commands).
  for (int i = 0; i < 4; i++)
    RED[i] = 0;
    BLUE[i] = 0;
    GREEN[i] = 0;
void updatestring()
    spi_tx8(HSPI, RED[i]);
    spi_tx8(HSPI, GREEN[i]);
    spi_tx8(HSPI, BLUE[i]);
void loop()
    RED[i] = 255; GREEN[i] = 0; BLUE[i] = 0;
    updatestring();
    RED[i] = 0; GREEN[i] = 0; BLUE[i] = 0;
    delay(200);
Ws 2801pixels Esp - 01 NeoPixelBus ESPAsyncE131
Code:
#define UNIVERSE_COUNT 8                // Total number of Universes to listen for, starting at UNIVERSE
const uint16_t PixelCount1 = 4; // this example assumes 4 pixels, making it smaller will cause a failure
// make sure to set this to the correct pins
const uint8_t DotClockPin = 0;
const uint8_t DotDataPin = 2;
const char passphrase[] = "";   // Replace with your WPA2 passphrase
NeoPixelBus<NeoRgbFeature, NeoWs2801Method> strip1(PixelCount1, DotClockPin, DotDataPin);
void setup() {
    delay(10);
    Serial.println("");
    Serial.print(ssid);
    else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
    Serial.println("");
    else
void loop() {
        strip1.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j +2])));
      strip1.Show();
LPD 6803 Esp-01 ESPAsyncE131 Fastled
Will probably work on CCR as they are just renamed from Lpd6803 I believe.
Code:
#define NUM_LEDS 5
#define DATA_PIN 2
#define CLOCK_PIN 0
void setup() {
    // sanity check delay - allows reprogramming if accidently blowing power w/leds
    delay(2000);
    delay(10);
    FastLED.addLeds<LPD6803, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);  // GRB ordering is typical
    Serial.println("");
    Serial.print(ssid);
    else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
    Serial.println("");
    else
void loop() {
        leds[i] = (i, (CRGB(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j +2])));
      FastLED.show();
Esp-01 APA 102 pixels ESPAsyncE131
Code:
* E131_Test.ino - Simple sketch to listen for E1.31 data on an ESP32
*                  and print some statistics.
* Project: ESPAsyncE131 - Asynchronous E.131 (sACN) library for Arduino ESP8266 and ESP32
* Copyright (c) 2019 Shelby Merrick
* http://www.forkineye.com
*  This program is provided free for you to use in any way that you wish,
*  subject to the laws and regulations where you are using it.  Due diligence
*  is strongly suggested before using this code.  Please give credit where due.
*  The Author makes no warranty of any kind, express or implied, with regard
*  to this program or the documentation contained in this document.  The
*  Author shall not be liable in any event for incidental or consequential
*  damages in connection with, or arising out of, the furnishing, performance
*  or use of these programs.
const uint16_t PixelCount = 72; // this example assumes 4 pixels, making it smaller will cause a failure
NeoPixelBus<DotStarBgrFeature, DotStarMethod> strip(PixelCount, DotClockPin, DotDataPin);
void setup() {
  delay(10);
  Serial.println("");
  Serial.print(ssid);
  else
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  Serial.println("");
    pinMode(DotDataPin, OUTPUT);
    digitalWrite(DotDataPin, LOW);
    strip.Begin();
    strip.Show();
void loop() {
            strip.Show();
Thanks much for the E131 Test .ino . It was fun to test these sketches and learn a little along the way .
I managed to kill a few Esp modules in this process and have finally learned the value of protection diodes !
Just maybe some of you will find 1 or 2 of these useful.
Cheers
You sir, are a saint for sharing this. So happy to see someone else (who is more knowledgable than I) diving deep into figuring out how to drive neopixels from multiple gpio on the Esp8266 with FastLED! This is amazing! Thank you.
I'll be going through everything you posted in this thread for a while, but so far I notice that you changed up the hardware used at various points. Would you mind sharing your setup?
Many here will say and I have to agree , I am no saint . More of a cantankerous character better suited !
This site and member here have given me loads of guidance over the years so this is my way of giving back .
As far as setup , do you mean Arduino IDE ?
If yes , I use the 1.8.12 version .
I have to switch the esp8266 board version from most recent to -> 4.2 from time to time and the ArduinoJason
from most recent to -> 5.1 or 5.0 when it complains .
Also as I experimented with this I had to vary the Fastled lib version as I did not realize I was not current .
The ws2801 was a bit of frustration and found Wled was best for them .
Back
Top
